Hello all,
As the title suggests: I am having this error with low probability. It did not always show up, but when it showed up, it was always the last a few messages I could see in /var/log/kern.log before a manual system reboot. BTW, the OS uses extlinux to boot.
Here is the error messages:
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.272152] sdhci: ================== REGISTER DUMP (mmc1)==================
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.279250] sdhci: Sys addr[0x000]: 0x00000000 | Version[0x0fe]: 0x00000303
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.286322] sdhci: Blk size[0x004]: 0x00007080 | Blk cnt[0x006]: 0x00000000
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.293392] sdhci: Argument[0x008]: 0x12003e00 | Trn mode[0x00c]: 0x00000000
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.300463] sdhci: Present[0x024]: 0x01fb00f0 | Host ctl[0x028]: 0x00000013
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.307530] sdhci: Power[0x029]: 0x0000000d | Blk gap[0x02a]: 0x00000000
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.314596] sdhci: Wake-up[0x02b]: 0x00000000 | Clock[0x02c]: 0x00000007
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.321661] sdhci: Timeout[0x02e]: 0x0000000e | Int stat[0x030]: 0x00000000
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.328726] sdhci: Int enab[0x034]: 0x02ff000b | Sig enab[0x038]: 0x02fc000b
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.335791] sdhci: AC12 err[0x03c]: 0x00000000 | Slot int[0x0fc]: 0x00000000
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.342861] sdhci: Caps[0x040]: 0x376cd08c | Caps_1[0x044]: 0x10006f73
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.349927] sdhci: Cmd[0x00e]: 0x0000341a | Max curr[0x048]: 0x00000000
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.356987] sdhci: Host ctl2[0x03e]: 0x0000300b
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.361543] sdhci: ADMA Err[0x054]: 0x00000000 | ADMA Ptr[0x058]: 0xfdd00010
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368613] mmc1: tuning_window[0]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368639] mmc1: tuning_window[1]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368665] mmc1: tuning_window[2]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368688] mmc1: tuning_window[3]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368711] mmc1: tuning_window[4]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368734] mmc1: tuning_window[5]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368756] mmc1: tuning_window[6]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368779] mmc1: tuning_window[7]: 0x0
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368799] sdhci: Tap value: 48 | Trim value: 8
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368819] sdhci: SDMMC Interrupt status: 0x00040000
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.368833] sdhci: =========================================================
Aug 14 17:07:03 tegra-ubuntu kernel: [ 1726.375896] mmc1: Command CRC error, intmask: 60001 Interface clock = 204000000Hz
I am aware of posts like https://devtalk.nvidia.com/default/topic/954715/jetson-tk1/mmc2-timeout-waiting-for-hardware-interrupt-solved-with-issues-/ and https://devtalk.nvidia.com/default/topic/883906/custom-tegra-k1-board-mmc-problem-/ , but I still don’t know how to address this issue, especially when it does not always happen. LOL. And, I am a newbie on this topic.
A full log is pasted in https://pastebin.com/MB6TQWAz
Here is a grep I did from the full log:
~$ grep -i 'mmc1' one_log.txt
Aug 14 16:38:21 tegra-ubuntu kernel: [ 0.269090] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV with ramp delay 100000 uV/us ; Rail ON
Aug 14 16:38:21 tegra-ubuntu kernel: [ 0.331485] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.471365] mmc1: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.487997] mmc1: no vqmmc regulator found
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.494048] mmc1: no vmmc regulator found
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.531185] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.758235] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952066] mmc1: tap value and tuning window after hw tuning completion ...
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952076] mmc1: tuning_window[0]: 0x8fffffff
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952084] mmc1: tuning_window[1]: 0xffffffff
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952091] mmc1: tuning_window[2]: 0xffffffc7
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952097] mmc1: tuning_window[3]: 0x7fffe3ff
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952104] mmc1: tuning_window[4]: 0x0
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952111] mmc1: tuning_window[5]: 0x0
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952118] mmc1: tuning_window[6]: 0x0
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.952124] mmc1: tuning_window[7]: 0x0
Aug 14 16:38:21 tegra-ubuntu kernel: [ 1.963690] mmc1: new ultra high speed SDR104 SDIO card at address 0001
Aug 14 16:38:21 tegra-ubuntu kernel: [ 2.438497] sdmmc1_ddr
Aug 14 16:38:21 tegra-ubuntu NetworkManager[548]: <info> [1502728701.4441] rfkill1: found WiFi radio killswitch (at /sys/devices/platform/sdhci-tegra.1/mmc_host/mmc1/mmc1:0001/mmc1:0001:2/ieee80211/phy0/rfkill1) (driver bcmsdh_sdmmc)
Aug 14 16:38:21 tegra-ubuntu NetworkManager[548]: <info> [1502728701.4452] rfkill2: found WiFi radio killswitch (at /sys/devices/platform/sdhci-tegra.1/mmc_host/mmc1/mmc1:0001/mmc1:0001:2/rfkill/rfkill2) (driver bcmsdh_sdmmc)
Aug 14 16:38:21 tegra-ubuntu NetworkManager[548]: <info> [1502728701.7048] devices added (path: /sys/devices/platform/sdhci-tegra.1/mmc_host/mmc1/mmc1:0001/mmc1:0001:2/net/wlan0, iface: wlan0)
Aug 14 16:38:21 tegra-ubuntu NetworkManager[548]: <info> [1502728701.7049] device added (path: /sys/devices/platform/sdhci-tegra.1/mmc_host/mmc1/mmc1:0001/mmc1:0001:2/net/wlan0, iface: wlan0): no ifupdown configuration found.
Aug 14 16:38:22 tegra-ubuntu kernel: [ 5.539028] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
After flashed jetpack 2.3.1 to TX1, I recompiled the kernel following instructions on this page: http://www.jetsonhacks.com/2016/09/28/build-tx1-kernel-and-modules-nvidia-jetson-tx1/ in order to enable SocketCAN support. I later added gpio-to-sfio in gpio@6000d000 to the device tree in order to use spi0 for CAN traffic.
Here is what I did:
default {
gpio-to-sfio = <0x10 0x11 0x12 0x13>
My TX1 worked perfectly except it sometimes shuts down itself and never come back unless I manually boot up it again.
Any help is appreciated, thanks!
