Hello Team.
Our server has a slow internet connection, and after a certain period, it encounters the following error and terminates.
We are running this on a node equipped with 8× NVIDIA B200 GPUs, using the command below:
docker run -it --rm --name=parakeet-1-1b-rnnt-multilingual \
--runtime=nvidia \
--gpus '"device=0"' \
--shm-size=8GB \
-e NGC_API_KEY \
-e NIM_HTTP_API_PORT=9000 \
-e NIM_GRPC_API_PORT=50051 \
-e NIM_TAGS_SELECTOR=mode=all \
-e NIM_CACHE_PATH=/opt/nim/.cache \
-v [local_path]:/opt/nim/.cache \
-p 9000:9000 \
-p 50051:50051 \
nvcr.io/nim/nvidia/parakeet-1-1b-rnnt-multilingual:latest
Because of the slow network, the model download process fails after some time with the following error:
RuntimeError: Download Error: RequestError(reqwest::Error { kind: Decode, source: hyper::Error(Body, Os { code: 104, kind: ConnectionReset, message: "Connection reset by peer" }) })
As a result, the startup process stops with:
nimlib.exceptions.ManifestDownloadError: Error downloading manifest: RuntimeError: Download Error: RequestError(reqwest::Error { kind: Decode, source: hyper::Error(Body, Os { code: 104, kind: ConnectionReset, message: "Connection reset by peer" }) })
Our server times out due to the slow internet connection, and we’re looking for a way to prevent this issue or resume the download process instead of restarting everything.
Is there a way to use cached model files that were downloaded and stored on another server by moving them into the NIM_CACHE_PATH directory?
Alternatively, can I configure any environment variables to prevent the timeout issue caused by a slow network connection?
If there are any other potential solutions, I’d like to know about them as well.
Thank you in advance for your help and guidance.
Jade
