Sure, here you go -
ssd_config {
aspect_ratios_global: “[1.0, 2.0, 0.5, 3.0, 1.0/3.0]”
scales: “[0.05, 0.1, 0.25, 0.4, 0.55, 0.7, 0.85]”
two_boxes_for_ar1: true
clip_boxes: false
loss_loc_weight: 0.8
focal_loss_alpha: 0.25
focal_loss_gamma: 2.0
variances: “[0.1, 0.1, 0.2, 0.2]”
arch: “resnet18”
freeze_bn: false
freeze_blocks: 0
training_config {
batch_size_per_gpu: 16
num_epochs: 180
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-5
max_learning_rate: 2e-2
soft_start: 0.1
annealing: 0.3
regularizer {
type: L1
weight: 3.00000002618e-09
eval_config {
validation_period_during_training: 10
average_precision_mode: SAMPLE
batch_size: 32
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.01
clustering_iou_threshold: 0.6
top_k: 200
augmentation_config {
preprocessing {
output_image_width: 1248
output_image_height: 384
output_image_channel: 3
crop_right: 1248
crop_bottom: 384
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 0.7
zoom_max: 1.8
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
dataset_config {
data_sources: {
tfrecords_path: “/workspace/tlt/dataset/package_watch_small/7000/tfrecords/package_watch_trainval_7000*”
image_directory_path: “/workspace/tlt/dataset/package_watch_small/7000”
image_extension: “jpg”
target_class_mapping {
key: “person”
value: “person”
key: “package”
value: “package”
key: “automobile”
value: “automobile”
key: “Animal”
value: “animal”
key: “face”
value: “face”
validation_fold: 0
. tlt-train-g1 ssd -e /workspace/tlt/dataset/package_watch_small/7000/specs/ssd_train_resnet18_pkg_watch_7000.txt -r /workspace/tlt/dataset/package_watch_small/7000/training-new -k -m /workspace/tlt/train-and-test/pkg_watch_experiment_dir_unpruned/weights/ssd_resnet18_epoch_180.tlt
Using TensorFlow backend.
2019-12-14 17:02:10.707119: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-12-14 17:02:11.404978: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:998] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-14 17:02:11.405849: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x55fe6d0 executing computations on platform CUDA. Devices:
2019-12-14 17:02:11.405897: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): Tesla V100-SXM2-16GB, Compute Capability 7.0
2019-12-14 17:02:11.408252: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 2200000000 Hz
2019-12-14 17:02:11.408602: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x5667470 executing computations on platform Host. Devices:
2019-12-14 17:02:11.408633: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): ,
2019-12-14 17:02:11.408932: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1433] Found device 0 with properties:
name: Tesla V100-SXM2-16GB major: 7 minor: 0 memoryClockRate(GHz): 1.53
pciBusID: 0000:00:04.0
totalMemory: 15.75GiB freeMemory: 15.44GiB
2019-12-14 17:02:11.408961: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-12-14 17:02:11.409997: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-12-14 17:02:11.410024: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0
2019-12-14 17:02:11.410032: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0: N
2019-12-14 17:02:11.410121: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 15024 MB memory) → physical GPU (device: 0, name: Tesla V100-SXM2-16GB, pci bus id: 0000:00:04.0, compute capability: 7.0)
2019-12-14 17:02:11,412 [INFO] iva.ssd.scripts.train: Loading experiment spec at /workspace/tlt/dataset/package_watch_small/7000/specs/ssd_train_resnet18_pkg_watch_7000.txt.
2019-12-14 17:02:11,413 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from /workspace/tlt/dataset/package_watch_small/7000/specs/ssd_train_resnet18_pkg_watch_7000.txt
WARNING:tensorflow:From ./detectnet_v2/dataloader/utilities.py:114: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
Instructions for updating:
Use eager execution and:
tf.data.TFRecordDataset(path)
2019-12-14 17:02:11,417 [WARNING] tensorflow: From ./detectnet_v2/dataloader/utilities.py:114: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/data/ops/iterator_ops.py:358: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
Colocations handled automatically by placer.
2019-12-14 17:02:11,474 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/data/ops/iterator_ops.py:358: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
WARNING:tensorflow:From ./ssd/utils/tensor_utils.py:31: setdiff1d (from tensorflow.python.ops.array_ops) is deprecated and will be removed after 2018-11-30.
This op will be removed after the deprecation date. Please switch to tf.sets.difference().
2019-12-14 17:02:21,705 [WARNING] tensorflow: From ./ssd/utils/tensor_utils.py:31: setdiff1d (from tensorflow.python.ops.array_ops) is deprecated and will be removed after 2018-11-30.
2019-12-14 17:02:38,108 [INFO] iva.ssd.scripts.train: Loading pretrained weights. This may take a while…
/usr/local/lib/python2.7/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was not compiled. Compile it manually.
warnings.warn('No training configuration found in save file: ’
Layer (type) Output Shape Param # Connected to
Input (InputLayer) (16, 3, 384, 1248) 0
conv1 (Conv2D) (16, 64, 192, 624) 9472 Input[0][0]
bn_conv1 (BatchNormalization) (16, 64, 192, 624) 256 conv1[0][0]
activation_18 (Activation) (16, 64, 192, 624) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (16, 64, 96, 312) 36928 activation_18[0][0]
block_1a_bn_1 (BatchNormalizati (16, 64, 96, 312) 256 block_1a_conv_1[0][0]
activation_19 (Activation) (16, 64, 96, 312) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (16, 64, 96, 312) 36928 activation_19[0][0]
block_1a_conv_shortcut (Conv2D) (16, 64, 96, 312) 4160 activation_18[0][0]
block_1a_bn_2 (BatchNormalizati (16, 64, 96, 312) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (16, 64, 96, 312) 256 block_1a_conv_shortcut[0][0]
add_9 (Add) (16, 64, 96, 312) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
activation_20 (Activation) (16, 64, 96, 312) 0 add_9[0][0]
block_1b_conv_1 (Conv2D) (16, 64, 96, 312) 36928 activation_20[0][0]
block_1b_bn_1 (BatchNormalizati (16, 64, 96, 312) 256 block_1b_conv_1[0][0]
activation_21 (Activation) (16, 64, 96, 312) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (16, 64, 96, 312) 36928 activation_21[0][0]
block_1b_conv_shortcut (Conv2D) (16, 64, 96, 312) 4160 activation_20[0][0]
block_1b_bn_2 (BatchNormalizati (16, 64, 96, 312) 256 block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (16, 64, 96, 312) 256 block_1b_conv_shortcut[0][0]
add_10 (Add) (16, 64, 96, 312) 0 block_1b_bn_2[0][0]
block_1b_bn_shortcut[0][0]
activation_22 (Activation) (16, 64, 96, 312) 0 add_10[0][0]
block_2a_conv_1 (Conv2D) (16, 128, 48, 156) 73856 activation_22[0][0]
block_2a_bn_1 (BatchNormalizati (16, 128, 48, 156) 512 block_2a_conv_1[0][0]
activation_23 (Activation) (16, 128, 48, 156) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (16, 128, 48, 156) 147584 activation_23[0][0]
block_2a_conv_shortcut (Conv2D) (16, 128, 48, 156) 8320 activation_22[0][0]
block_2a_bn_2 (BatchNormalizati (16, 128, 48, 156) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (16, 128, 48, 156) 512 block_2a_conv_shortcut[0][0]
add_11 (Add) (16, 128, 48, 156) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
activation_24 (Activation) (16, 128, 48, 156) 0 add_11[0][0]
block_2b_conv_1 (Conv2D) (16, 128, 48, 156) 147584 activation_24[0][0]
block_2b_bn_1 (BatchNormalizati (16, 128, 48, 156) 512 block_2b_conv_1[0][0]
activation_25 (Activation) (16, 128, 48, 156) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (16, 128, 48, 156) 147584 activation_25[0][0]
block_2b_conv_shortcut (Conv2D) (16, 128, 48, 156) 16512 activation_24[0][0]
block_2b_bn_2 (BatchNormalizati (16, 128, 48, 156) 512 block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (16, 128, 48, 156) 512 block_2b_conv_shortcut[0][0]
add_12 (Add) (16, 128, 48, 156) 0 block_2b_bn_2[0][0]
block_2b_bn_shortcut[0][0]
activation_26 (Activation) (16, 128, 48, 156) 0 add_12[0][0]
block_3a_conv_1 (Conv2D) (16, 256, 24, 78) 295168 activation_26[0][0]
block_3a_bn_1 (BatchNormalizati (16, 256, 24, 78) 1024 block_3a_conv_1[0][0]
activation_27 (Activation) (16, 256, 24, 78) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (16, 256, 24, 78) 590080 activation_27[0][0]
block_3a_conv_shortcut (Conv2D) (16, 256, 24, 78) 33024 activation_26[0][0]
block_3a_bn_2 (BatchNormalizati (16, 256, 24, 78) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (16, 256, 24, 78) 1024 block_3a_conv_shortcut[0][0]
add_13 (Add) (16, 256, 24, 78) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
activation_28 (Activation) (16, 256, 24, 78) 0 add_13[0][0]
block_3b_conv_1 (Conv2D) (16, 256, 24, 78) 590080 activation_28[0][0]
block_3b_bn_1 (BatchNormalizati (16, 256, 24, 78) 1024 block_3b_conv_1[0][0]
activation_29 (Activation) (16, 256, 24, 78) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (16, 256, 24, 78) 590080 activation_29[0][0]
block_3b_conv_shortcut (Conv2D) (16, 256, 24, 78) 65792 activation_28[0][0]
block_3b_bn_2 (BatchNormalizati (16, 256, 24, 78) 1024 block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (16, 256, 24, 78) 1024 block_3b_conv_shortcut[0][0]
add_14 (Add) (16, 256, 24, 78) 0 block_3b_bn_2[0][0]
block_3b_bn_shortcut[0][0]
activation_30 (Activation) (16, 256, 24, 78) 0 add_14[0][0]
block_4a_conv_1 (Conv2D) (16, 512, 24, 78) 1180160 activation_30[0][0]
block_4a_bn_1 (BatchNormalizati (16, 512, 24, 78) 2048 block_4a_conv_1[0][0]
activation_31 (Activation) (16, 512, 24, 78) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (16, 512, 24, 78) 2359808 activation_31[0][0]
block_4a_conv_shortcut (Conv2D) (16, 512, 24, 78) 131584 activation_30[0][0]
block_4a_bn_2 (BatchNormalizati (16, 512, 24, 78) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (16, 512, 24, 78) 2048 block_4a_conv_shortcut[0][0]
add_15 (Add) (16, 512, 24, 78) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
activation_32 (Activation) (16, 512, 24, 78) 0 add_15[0][0]
block_4b_conv_1 (Conv2D) (16, 512, 24, 78) 2359808 activation_32[0][0]
block_4b_bn_1 (BatchNormalizati (16, 512, 24, 78) 2048 block_4b_conv_1[0][0]
activation_33 (Activation) (16, 512, 24, 78) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (16, 512, 24, 78) 2359808 activation_33[0][0]
block_4b_conv_shortcut (Conv2D) (16, 512, 24, 78) 262656 activation_32[0][0]
block_4b_bn_2 (BatchNormalizati (16, 512, 24, 78) 2048 block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (16, 512, 24, 78) 2048 block_4b_conv_shortcut[0][0]
add_16 (Add) (16, 512, 24, 78) 0 block_4b_bn_2[0][0]
block_4b_bn_shortcut[0][0]
activation_34 (Activation) (16, 512, 24, 78) 0 add_16[0][0]
expand_conv1 (Conv2D) (16, 1024, 24, 78) 4719616 activation_34[0][0]
expand1_relu (ReLU) (16, 1024, 24, 78) 0 expand_conv1[0][0]
expand_conv2 (Conv2D) (16, 1024, 24, 78) 1049600 expand1_relu[0][0]
expand2_relu (ReLU) (16, 1024, 24, 78) 0 expand_conv2[0][0]
additional_map0_0 (Conv2D) (16, 256, 24, 78) 262400 expand2_relu[0][0]
additional_map0_0_relu (ReLU) (16, 256, 24, 78) 0 additional_map0_0[0][0]
additional_map0_1 (Conv2D) (16, 512, 12, 39) 1180160 additional_map0_0_relu[0][0]
additional_map0_1_relu (ReLU) (16, 512, 12, 39) 0 additional_map0_1[0][0]
additional_map1_0 (Conv2D) (16, 128, 12, 39) 65664 additional_map0_1_relu[0][0]
additional_map1_0_relu (ReLU) (16, 128, 12, 39) 0 additional_map1_0[0][0]
additional_map1_1 (Conv2D) (16, 256, 6, 20) 295168 additional_map1_0_relu[0][0]
additional_map1_1_relu (ReLU) (16, 256, 6, 20) 0 additional_map1_1[0][0]
additional_map2_0 (Conv2D) (16, 128, 6, 20) 32896 additional_map1_1_relu[0][0]
additional_map2_0_relu (ReLU) (16, 128, 6, 20) 0 additional_map2_0[0][0]
additional_map2_1 (Conv2D) (16, 256, 3, 10) 295168 additional_map2_0_relu[0][0]
additional_map2_1_relu (ReLU) (16, 256, 3, 10) 0 additional_map2_1[0][0]
additional_map3_0 (Conv2D) (16, 128, 3, 10) 32896 additional_map2_1_relu[0][0]
additional_map3_0_relu (ReLU) (16, 128, 3, 10) 0 additional_map3_0[0][0]
additional_map3_1 (Conv2D) (16, 256, 2, 5) 295168 additional_map3_0_relu[0][0]
additional_map3_1_relu (ReLU) (16, 256, 2, 5) 0 additional_map3_1[0][0]
ssd_conf_0 (Conv2D) (16, 30, 48, 156) 34590 activation_26[0][0]
ssd_conf_1 (Conv2D) (16, 30, 24, 78) 138270 activation_34[0][0]
ssd_conf_2 (Conv2D) (16, 30, 12, 39) 138270 additional_map0_1_relu[0][0]
ssd_conf_3 (Conv2D) (16, 30, 6, 20) 69150 additional_map1_1_relu[0][0]
ssd_conf_4 (Conv2D) (16, 30, 3, 10) 69150 additional_map2_1_relu[0][0]
ssd_conf_5 (Conv2D) (16, 30, 2, 5) 69150 additional_map3_1_relu[0][0]
permute_13 (Permute) (16, 48, 156, 30) 0 ssd_conf_0[0][0]
permute_15 (Permute) (16, 24, 78, 30) 0 ssd_conf_1[0][0]
permute_17 (Permute) (16, 12, 39, 30) 0 ssd_conf_2[0][0]
permute_19 (Permute) (16, 6, 20, 30) 0 ssd_conf_3[0][0]
permute_21 (Permute) (16, 3, 10, 30) 0 ssd_conf_4[0][0]
permute_23 (Permute) (16, 2, 5, 30) 0 ssd_conf_5[0][0]
ssd_loc_0 (Conv2D) (16, 24, 48, 156) 27672 activation_26[0][0]
ssd_loc_1 (Conv2D) (16, 24, 24, 78) 110616 activation_34[0][0]
ssd_loc_2 (Conv2D) (16, 24, 12, 39) 110616 additional_map0_1_relu[0][0]
ssd_loc_3 (Conv2D) (16, 24, 6, 20) 55320 additional_map1_1_relu[0][0]
ssd_loc_4 (Conv2D) (16, 24, 3, 10) 55320 additional_map2_1_relu[0][0]
ssd_loc_5 (Conv2D) (16, 24, 2, 5) 55320 additional_map3_1_relu[0][0]
conf_reshape_0 (Reshape) (16, 44928, 1, 5) 0 permute_13[0][0]
conf_reshape_1 (Reshape) (16, 11232, 1, 5) 0 permute_15[0][0]
conf_reshape_2 (Reshape) (16, 2808, 1, 5) 0 permute_17[0][0]
conf_reshape_3 (Reshape) (16, 720, 1, 5) 0 permute_19[0][0]
conf_reshape_4 (Reshape) (16, 180, 1, 5) 0 permute_21[0][0]
conf_reshape_5 (Reshape) (16, 60, 1, 5) 0 permute_23[0][0]
permute_14 (Permute) (16, 48, 156, 24) 0 ssd_loc_0[0][0]
permute_16 (Permute) (16, 24, 78, 24) 0 ssd_loc_1[0][0]
permute_18 (Permute) (16, 12, 39, 24) 0 ssd_loc_2[0][0]
permute_20 (Permute) (16, 6, 20, 24) 0 ssd_loc_3[0][0]
permute_22 (Permute) (16, 3, 10, 24) 0 ssd_loc_4[0][0]
permute_24 (Permute) (16, 2, 5, 24) 0 ssd_loc_5[0][0]
ssd_anchor_0 (AnchorBoxes) (16, 7488, 6, 8) 0 ssd_loc_0[0][0]
ssd_anchor_1 (AnchorBoxes) (16, 1872, 6, 8) 0 ssd_loc_1[0][0]
ssd_anchor_2 (AnchorBoxes) (16, 468, 6, 8) 0 ssd_loc_2[0][0]
ssd_anchor_3 (AnchorBoxes) (16, 120, 6, 8) 0 ssd_loc_3[0][0]
ssd_anchor_4 (AnchorBoxes) (16, 30, 6, 8) 0 ssd_loc_4[0][0]
ssd_anchor_5 (AnchorBoxes) (16, 10, 6, 8) 0 ssd_loc_5[0][0]
mbox_conf (Concatenate) (16, 59928, 1, 5) 0 conf_reshape_0[0][0]
conf_reshape_1[0][0]
conf_reshape_2[0][0]
conf_reshape_3[0][0]
conf_reshape_4[0][0]
conf_reshape_5[0][0]
loc_reshape_0 (Reshape) (16, 44928, 1, 4) 0 permute_14[0][0]
loc_reshape_1 (Reshape) (16, 11232, 1, 4) 0 permute_16[0][0]
loc_reshape_2 (Reshape) (16, 2808, 1, 4) 0 permute_18[0][0]
loc_reshape_3 (Reshape) (16, 720, 1, 4) 0 permute_20[0][0]
loc_reshape_4 (Reshape) (16, 180, 1, 4) 0 permute_22[0][0]
loc_reshape_5 (Reshape) (16, 60, 1, 4) 0 permute_24[0][0]
anchor_reshape_0 (Reshape) (16, 44928, 1, 8) 0 ssd_anchor_0[0][0]
anchor_reshape_1 (Reshape) (16, 11232, 1, 8) 0 ssd_anchor_1[0][0]
anchor_reshape_2 (Reshape) (16, 2808, 1, 8) 0 ssd_anchor_2[0][0]
anchor_reshape_3 (Reshape) (16, 720, 1, 8) 0 ssd_anchor_3[0][0]
anchor_reshape_4 (Reshape) (16, 180, 1, 8) 0 ssd_anchor_4[0][0]
anchor_reshape_5 (Reshape) (16, 60, 1, 8) 0 ssd_anchor_5[0][0]
mbox_conf_sigmoid (Activation) (16, 59928, 1, 5) 0 mbox_conf[0][0]
mbox_loc (Concatenate) (16, 59928, 1, 4) 0 loc_reshape_0[0][0]
loc_reshape_1[0][0]
loc_reshape_2[0][0]
loc_reshape_3[0][0]
loc_reshape_4[0][0]
loc_reshape_5[0][0]
mbox_priorbox (Concatenate) (16, 59928, 1, 8) 0 anchor_reshape_0[0][0]
anchor_reshape_1[0][0]
anchor_reshape_2[0][0]
anchor_reshape_3[0][0]
anchor_reshape_4[0][0]
anchor_reshape_5[0][0]
concatenate_2 (Concatenate) (16, 59928, 1, 17) 0 mbox_conf_sigmoid[0][0]
mbox_loc[0][0]
mbox_priorbox[0][0]
ssd_predictions (Reshape) (16, 59928, 17) 0 concatenate_2[0][0]
Total params: 20,710,468
Trainable params: 20,689,348
Non-trainable params: 21,120
2019-12-14 17:13:41,085 [INFO] iva.ssd.scripts.train: Number of images in the training dataset: 5600
2019-12-14 17:13:41,086 [INFO] iva.ssd.scripts.train: Number of images in the validation dataset: 1400
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/ops/math_ops.py:3066: to_int32 (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Use tf.cast instead.
2019-12-14 17:13:41,568 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/ops/math_ops.py:3066: to_int32 (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Epoch 1/180
2019-12-14 17:14:01.980712: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.980803: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.980857: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.980895: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.980942: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981005: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981038: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.981074: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.981154: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981195: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.981227: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981263: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981300: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981352: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981397: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.981440: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.981488: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981522: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.981557: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981594: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981631: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981668: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981702: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.981740: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.981788: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981823: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.981858: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981897: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981945: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.981985: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982022: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.982061: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.982113: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982151: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.982190: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982229: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982269: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982307: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982345: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.982392: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.982453: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982495: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.982538: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982588: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982628: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982667: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982705: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.982746: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.982793: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982854: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.982900: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982955: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.982997: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983032: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983067: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.983104: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.983151: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983185: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.983225: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983267: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983307: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983344: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983391: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-12-14 17:14:01.983426: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-12-14 17:14:01.983475: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983518: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-12-14 17:14:01.983556: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-12-14 17:14:01.983596: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAx
