Modification in Deepstream test4 python binding
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1.1
• TensorRT Version
I am testing deepstream test4 python binding example with Azure. It is sending the information correctly to Azure IOT Explorer. By default it is sending bounding box, frame number, object id, object make, type and so on. I want to modify the data to be send by deepstream test 4 example to Azure IOT Explorer. How can I do that?
as you know, deepstream sdk is a C lib, python use deepstream lib by python binding. nvmsgcov is responsible for packet message, and it is opensource. you can modify the code to customize, please refer to generate_dsmeta_message_minimal and generate_dsmeta_message_protobuf in \opt\nvidia\deepstream\deepstream-6.2\sources\libs\nvmsgconv\deepstream_schema.
