PERF {stream:0.0} Error in DeepStream Application with Azure IoT Hub Integration
• Hardware Platform - GPU
• DeepStream Version - 7.0
• TensorRT Version - 10.6.0
**• NVIDIA GPU Driver Version - 560.35.03 **
• Issue Type - questions
**• How to reproduce the issue ? **
In my DeepStream application, I’ve implemented custom code to create a JSON object and send it to Azure IoT Hub using the azure-iot-hub Python package. While the code works fine initially, after 6-7 hours, I receive the PERF {stream:0.0} message. I’m not sure what causes this issue, but I found that commenting out the code responsible for sending messages to Azure IoT Hub resolves the problem. It seems that this issue is not exclusive to the azure-iot-hub package—if I add any other connections, such as sending data to Event Hub or Azure Blob Storage, I encounter the same problem. I also checked the system’s memory, CPU, and GPU usage, and everything remains stable, so I’m unsure why this message occurs.
code :
import sys
sys.path.append('../')
import gi
import configparser
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from ctypes import *
import time
import sys
import math
import platform
from common.platform_info import PlatformInfo
import os
import pytz
from shapely.geometry import Point,Polygon
from datetime import datetime
import json
from common.bus_call import bus_call
from common.FPS import PERF_DATA
import argparse
import yaml
from utils import read_yaml,get_current_epoch_in_syd,epoch_to_datetime_str,convert_syd_epoch_to_datetime_str,send_message_to_iothub
import pyds
import multiprocessing
from send_to_blob import monitor_and_upload_videos
perf_data = None
MAX_DISPLAY_LEN=64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=1080
MUXER_BATCH_TIMEOUT_USEC = 33000
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
GST_CAPS_FEATURES_NVMM="memory:NVMM"
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
syd_tz = pytz.timezone('Australia/Sydney')
yaml_con = read_yaml("main_config.yaml")
cap_fps = int(yaml_con["fps"])
json_write_ther = int(yaml_con["json_write_ther"])
base_json_dir_name = yaml_con["base_json_dir_name"]
base_video_dir_name = yaml_con["base_video_dir_name"]
sec_to_get_data = int(yaml_con["sec_to_get_data"])
iot_hub_connection_string = yaml_con["iot_hub_connection_string"]
no_min_to_write_video = int(yaml_con["no_min_to_write_video"])
def parse_args():
    parser = argparse.ArgumentParser(prog="deepstream_demux_multi_in_multi_out.py",
        description="deepstream-demux-multi-in-multi-out takes multiple URI streams as input" \
            "and uses `nvstreamdemux` to split batches and output separate buffer/streams")
    parser.add_argument(
        "-i",
        "--input",
        help="Path to input streams",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
    args = parser.parse_args()
    stream_paths = args.input
    return stream_paths
args = parse_args()
print(f"=================================> {args}")
# cap_fps = 8
# base_json_dir_name = "jsons"
# base_video_dir_name = "videos"
# json_write_ther = 60
# sec_to_get_data = 1
# iot_hub_connection_string = "connection-str"
# no_min_to_write_video = 300
one_min_counter = 60*cap_fps
start_time = {i:get_current_epoch_in_syd() for i in range(len(args))}
one_min_start_time  = {i:get_current_epoch_in_syd() for i in range(len(args))}
current_date = datetime.fromtimestamp(get_current_epoch_in_syd(), syd_tz).strftime('%Y-%m-%d')
video_dir_paths = {i:os.path.join(base_video_dir_name,f"{i}",current_date) for i in range(len(args))}
dir_names = {i:os.path.join(base_json_dir_name,f"{i}",current_date) for i in range(len(args))}
[os.makedirs(dir_names[i],exist_ok=True) for i in range(len(args))]
[os.makedirs(video_dir_paths[i],exist_ok=True) for i in range(len(args)) ]
data_dict = { i:{"people_crossing":[],"people_crossing_frame":[x],"people_count":[]} for i in range(len(args)) }
camera_ids = {idx:cam_id for idx,cam_id in enumerate(["C1085","C2034","C2035"])}
data_dict_1_min = { i:{"people_crossing_cumulative":[],"people_crossing_frame":[],"people_count":[],"track_ids":[],"camera_id":camera_ids[i]} for i in range(len(args)) }
object_track_id_conf = {i:{} for i in range(len(args)) }
def make_elm_or_print_err(factoryname, name, printedname, detail=""):
    """ Creates an element with Gst Element Factory make.
        Return the element  if successfully created, otherwise print
        to stderr and return None.
    print("Creating", printedname)
    elm = Gst.ElementFactory.make(factoryname, name)
    if not elm:
        sys.stderr.write("Unable to create " + printedname + " \n")
        if detail:
            sys.stderr.write(detail)
    return elm
def make_element(element_name, i):
    Creates a Gstreamer element with unique name
    Unique name is created by adding element type and index e.g. `element_name-i`
    Unique name is essential for all the element in pipeline otherwise gstreamer will throw exception.
    :param element_name: The name of the element to create
    :param i: the index of the element in the pipeline
    :return: A Gst.Element object
    element = Gst.ElementFactory.make(element_name, element_name)
    if not element:
        sys.stderr.write(" Unable to create {0}".format(element_name))
    element.set_property("name", "{0}-{1}".format(element_name, str(i)))
    return element
def nvanalytics_src_pad_buffer_probe(pad,info,u_data):
    global start_time
    # global data_dict_1_min
    frame_number=0
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number=frame_meta.frame_num
        l_obj=frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        obj_counter = {
        PGIE_CLASS_ID_VEHICLE:0,
        PGIE_CLASS_ID_PERSON:0,
        PGIE_CLASS_ID_BICYCLE:0,
        PGIE_CLASS_ID_ROADSIGN:0
        print("#"*50)
        stream_id = frame_meta.pad_index
        while l_obj:
            try:
                # Note that l_obj.data needs a cast to pyds.NvDsObjectMeta
                # The casting is done by pyds.NvDsObjectMeta.cast()
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                track_id = obj_meta.object_id
                conf = obj_meta.confidence
                if track_id not in object_track_id_conf[stream_id]:
                    object_track_id_conf[stream_id][track_id] = [conf]
                else:
                    object_track_id_conf[stream_id][track_id].append(conf)
                break
            obj_counter[obj_meta.class_id] += 1
            l_user_meta = obj_meta.obj_user_meta_list
            # Extract object level meta data from NvDsAnalyticsObjInfo
            while l_user_meta:
                try:
                    user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
                    if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSOBJ.USER_META"):
                        user_meta_data = pyds.NvDsAnalyticsObjInfo.cast(user_meta.user_meta_data)
                        if user_meta_data.dirStatus: print("Object {0} moving in direction: {1}".format(obj_meta.object_id, user_meta_data.dirStatus))
                        if user_meta_data.lcStatus: print("Object {0} line crossing status: {1}".format(obj_meta.object_id, user_meta_data.lcStatus))
                        if user_meta_data.ocStatus: print("Object {0} overcrowding status: {1}".format(obj_meta.object_id, user_meta_data.ocStatus))
                        if user_meta_data.roiStatus: print("Object {0} roi status: {1}".format(obj_meta.object_id, user_meta_data.roiStatus))
                    break
                try:
                    l_user_meta = l_user_meta.next
                    break
            try:
                l_obj=l_obj.next
                break
        # Get meta data from NvDsAnalyticsFrameMeta
        l_user = frame_meta.frame_user_meta_list
        counter  = 0
        while l_user:
            try:
                user_meta = pyds.NvDsUserMeta.cast(l_user.data)
                if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META"):
                    user_meta_data = pyds.NvDsAnalyticsFrameMeta.cast(user_meta.user_meta_data)
                    if user_meta_data.objInROIcnt:
                        print("Objs in ROI: {0}".format(user_meta_data.objInROIcnt))
                    if user_meta_data.objLCCumCnt: print("Linecrossing Cumulative: {0}".format(user_meta_data.objLCCumCnt))
                    if user_meta_data.objLCCurrCnt: print("Linecrossing Current Frame: {0}".format(user_meta_data.objLCCurrCnt))
                    if user_meta_data.ocStatus: print("Overcrowding status: {0}".format(user_meta_data.ocStatus))
                break
            try:
                l_user = l_user.next
                break
        # track_ids_json_path = os.path.join(f"track_ids_{stream_id}",f"track_ids_{stream_id}_{frame_number}.json")
        # with open(track_ids_json_path, 'w') as f:
        #     json.dump(object_track_id_conf, f,indent=4)
        stream_index = "stream{0}".format(stream_id)
        data_dict[stream_id]["people_count"].append({"data":user_meta_data.objInROIcnt['RF']
            data_dict[stream_id]["people_crossing"].append({"data":user_meta_data.objLCCumCnt})
        current_epoch = get_current_epoch_in_syd()
        current_time_str = convert_syd_epoch_to_datetime_str(current_epoch)
        try:
            if (get_current_epoch_in_syd() - start_time[stream_id]) >= sec_to_get_data:
                people_count = [ d["data"] for d in data_dict[stream_id]["people_count"] ]
                track_ids = [{track_id : sum(confs)/len(confs)} for track_id,confs in object_track_id_conf[stream_id].items()]
                data_dict_1_min[stream_id]["track_ids"].append({"track_ids":track_ids,"current_time_str":current_time_str})
                people_count_avg = sum(people_count)/len(people_count)
                people_count_max = max(people_count)
                people_count_min = min(people_count)
                data_dict_1_min[stream_id]["people_count"].append({"data":{"avg":people_count_avg,"max":people_count_max,
        "min":people_count_min},"current_time_str":current_time_str,"frame_no":frame_number})
                    people_crossing_entry = [ d["data"]["Entry"] for d in data_dict[stream_id]["people_crossing"] ]
                    people_crossing_exit = [ d["data"]["Exit"] for d in data_dict[stream_id]["people_crossing"] ]
                    # people_count = sum(people_count)/len(people_count)
                    people_crossing_entry_max = max(people_crossing_entry)
                    people_crossing_entry_min = min(people_crossing_entry)
                    people_crossing_entry_avg = sum(people_crossing_entry)/len(people_crossing_entry)
                    people_crossing_exit_max = max(people_crossing_exit)
                    people_crossing_exit_min = min(people_crossing_exit)
                    people_crossing_exit_avg = sum(people_crossing_exit)/len(people_crossing_exit)
                    data_dict_1_min[stream_id]["people_crossing_cumulative"].append({"data":{"entry":{"avg":people_crossing_entry_avg,"max":people_crossing_entry_max,
        "min":people_crossing_entry_min},"exit":{"avg":people_crossing_exit_avg,"max":people_crossing_exit_max,
        "min":people_crossing_exit_min}},"current_time_str":current_time_str,"frame_no":frame_number})
                    # data_dict_1_min[stream_id]["people_count"].append({"data":people_count,"current_time_str":current_time_str})
                    data_dict_1_min[stream_id]["people_crossing_frame"].append(
        {"data":user_meta_data.objLCCurrCnt,"current_time_str":current_time_str,"frame_no":frame_number}
                # else:
                data_dict[stream_id]["people_count"] = []
                data_dict[stream_id]["people_crossing"] = []
                data_dict[stream_id]["people_crossing_frame"] = []
                object_track_id_conf[stream_id] = {}
                start_time[stream_id] = get_current_epoch_in_syd()
            data_dict_1_min[stream_id]["frame_no"] = frame_number
            if (get_current_epoch_in_syd() - one_min_start_time[stream_id]) >= json_write_ther:
                file_path = os.path.join(dir_names[stream_id],f"{current_time_str}.json")
                with open(file_path,"w") as f:
                    json.dump(data_dict_1_min[stream_id],f,indent=4)
                s= time.time()
                send_message_to_iothub(iot_hub_connection_string,json.dumps(data_dict_1_min[stream_id]))
                print(f"\n =================================== total time taken send the msg to iot hub {(time.time() - s):.2} =================================== \n")
                data_dict_1_min[stream_id]["people_count"] = []
                data_dict_1_min[stream_id]["people_crossing"] = []
                data_dict_1_min[stream_id]["people_crossing_frame"] = []
                data_dict_1_min[stream_id]["people_crossing_cumulative"] = []
                data_dict_1_min[stream_id]["track_ids"] = []
                one_min_start_time[stream_id] =  get_current_epoch_in_syd()
                print(f"data saved successfully to file {file_path}")
        except Exception as e:
            raise e
        print("Frame Number=", frame_number, "stream id=", frame_meta.pad_index, "Number of Objects=",num_rects,"Vehicle_count=",obj_counter[PGIE_CLASS_ID_VEHICLE],"Person_count=",obj_counter[PGIE_CLASS_ID_PERSON])
        # Update frame rate through this probe
        stream_index = "stream{0}".format(frame_meta.pad_index)
        global perf_data
        perf_data.update_fps(stream_index)
        try:
            l_frame=l_frame.next
            break
        print("#"*50)
    return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad,data):
    print("In cb_newpad\n")
    caps=decoder_src_pad.get_current_caps()
    gststruct=caps.get_structure(0)
    gstname=gststruct.get_name()
    source_bin=data
    features=caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=",gstname)
    if(gstname.find("video")!=-1):
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=",features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad=source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
    print("Decodebin child added:", name, "\n")
    if(name.find("decodebin") != -1):
        Object.connect("child-added",decodebin_child_added,user_data)
def create_source_bin(index,uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name="source-bin-%02d" %index
    print(bin_name)
    nbin=Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri",uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added",cb_newpad,nbin)
    uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin,uri_decode_bin)
    bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def format_location_callback(splitmuxsink, fragment_id, video_dir_path, stream_id):
    # Get the current date and time
    current_datetime = datetime.now().strftime("%Y-%m-%d_%H-%M-%S")
    # Construct the filename with the current datetime
    return os.path.join(video_dir_path, f"stream_{stream_id}_rtsp_out_{current_datetime}.mp4")
def main(args):
    input_sources = args
    number_sources = len(input_sources)
    global perf_data
    perf_data = PERF_DATA(number_sources)
    platform_info = PlatformInfo()
    # Standard GStreamer initialization
    Gst.init(None)
    Gst.init(None)
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ",i," \n ")
        uri_name=args[i]
        if uri_name.find("rtsp://") == 0 :
            is_live = True
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.request_pad_simple(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
    queue1=Gst.ElementFactory.make("queue","queue1")
    queue2=Gst.ElementFactory.make("queue","queue2")
    queue3=Gst.ElementFactory.make("queue","queue3")
    queue4=Gst.ElementFactory.make("queue","queue4")
    queue5=Gst.ElementFactory.make("queue","queue5")
    queue6=Gst.ElementFactory.make("queue","queue6")
    queue7=Gst.ElementFactory.make("queue","queue7")
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(queue3)
    pipeline.add(queue4)
    pipeline.add(queue5)
    pipeline.add(queue6)
    pipeline.add(queue7)
    print("Creating Pgie")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    pgie.set_property('config-file-path', "dsnvanalytics_pgie_config.txt")
    pgie_batch_size=pgie.get_property("batch-size")
    if(pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
        pgie.set_property("batch-size",number_sources)
    print("Creating nvtracker")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    #Set properties of tracker
    config = configparser.ConfigParser()
    config.read('dsnvanalytics_tracker_config.txt')
    config.sections()
    for key in config['tracker']:
        if key == 'tracker-width' :
            tracker_width = config.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
    print("Creating nvdsanalytics")
    nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
    if not nvanalytics:
        sys.stderr.write(" Unable to create nvanalytics \n")
    nvanalytics.set_property("config-file", "config_nvdsanalytics.txt")
    print("Creating nvvidconv")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvosd.set_property('process-mode',OSD_PROCESS_MODE)
    nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
    print("Creating nvstreamdemux")
    nvstreamdemux = Gst.ElementFactory.make("nvstreamdemux", "nvstreamdemux")
    if not nvstreamdemux:
        sys.stderr.write(" Unable to create nvstreamdemux \n")
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(nvanalytics)
    pipeline.add(nvstreamdemux)
    streammux.link(queue1)
    queue1.link(pgie)
    pgie.link(tracker)
    tracker.link(nvanalytics)
    nvanalytics.link(nvstreamdemux)
        queue = make_element("queue", i)
        pipeline.add(queue)
        nvvideoconvert = make_element("nvvideoconvert", i)
        pipeline.add(nvvideoconvert)
        nvdsosd = make_element("nvdsosd", i)
        pipeline.add(nvdsosd)
        nvdsosd.set_property("process-mode", OSD_PROCESS_MODE)
        nvdsosd.set_property("display-text", OSD_DISPLAY_TEXT)
        # connect nvstreamdemux -> queue
        padname = "src_%u" % i
        demuxsrcpad = nvstreamdemux.request_pad_simple(padname)
        if not demuxsrcpad:
            sys.stderr.write("Unable to create demux src pad \n")
        queuesinkpad = queue.get_static_pad("sink")
        if not queuesinkpad:
            sys.stderr.write("Unable to create queue sink pad \n")
        demuxsrcpad.link(queuesinkpad)
        #save video
        queue10 = make_element("queue", f"queue10_{i}")
        nvvidconv2 = make_element("nvvideoconvert", f"nvvideoconvert_{i}")
        capsfilter = make_element("capsfilter", f"capsfilter_{i}")
        caps = Gst.Caps.from_string("video/x-raw, format=I420")
        capsfilter.set_property("caps", caps)
        encoder = make_element("avenc_mpeg4", f"encode_{i}")
        encoder.set_property("bitrate", 2000000)
        codeparser = make_element("mpeg4videoparse", f"mpeg4-parser_{i}")
        # splitmuxsink for rtsp save data every 1 min
        splitmuxsink = Gst.ElementFactory.make("splitmuxsink", f"splitmuxsink_{i}")
        if not splitmuxsink:
            sys.stderr.write("Unable to create splitmuxsink\n")
        current_date = datetime.now().strftime("%Y-%m-%d")
        # fn = os.path.join(video_dir_path,"stream_" + str(i) + "_rtsp_out_%03d.mp4")
        # fn = os.path.join(video_dir_path, f"stream_{i}_rtsp_out_{current_date}.mp4")
        # splitmuxsink.set_property("location",
        #                           fn)
        splitmuxsink.connect("format-location", format_location_callback, video_dir_paths[i], i)
        splitmuxsink.set_property("max-size-time", (no_min_to_write_video*60) * Gst.SECOND)  # 1-minute file duration
        muxer = Gst.ElementFactory.make("qtmux", "mp4mux")
        splitmuxsink.set_property("muxer", muxer)  # Assign the muxer to splitmuxsink
        pipeline.add(queue10)
        pipeline.add(nvvidconv2)
        pipeline.add(capsfilter)
        pipeline.add(encoder)
        pipeline.add(codeparser)
        pipeline.add(splitmuxsink)
        queue.link(nvvideoconvert)
        nvvideoconvert.link(nvdsosd)
        nvdsosd.link(queue10)
        queue10.link(nvvidconv2)
        nvvidconv2.link(capsfilter)
        capsfilter.link(encoder)
        encoder.link(codeparser)
        codeparser.link(splitmuxsink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    nvanalytics_src_pad=nvanalytics.get_static_pad("src")
    if not nvanalytics_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        nvanalytics_src_pad.add_probe(Gst.PadProbeType.BUFFER,
                                      nvanalytics_src_pad_buffer_probe, 0)
        # perf callback function to print fps every 5 sec
        GLib.timeout_add(5000, perf_data.perf_print_callback)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(args):
        if (i != 0):
            print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
if __name__ == "__main__":
    stream_paths = parse_args()
    connection_string = "conection_str"
    container_name = "videoanalytics"
    blob_video_path = "deepstream-immigration"
    chunk_mb_size = 10
    deep_stream_process = multiprocessing.Process(target=main,args=(stream_paths,))
    send_video_process = multiprocessing.Process(target=monitor_and_upload_videos,args=("videos_test_29/*/*/*.mp4", connection_string, container_name, chunk_mb_size,blob_video_path))
    deep_stream_process.start()
    send_video_process.start()
    deep_stream_process.join()
    send_video_process.join()
    # sys.exit()
seems it is related to sending broker. you can add log to measure the time consumption of sending broker. if it cost too much tome sometimes, please using a new thread to sending.
Which method is better for sending messages to IoT using Python in my application that runs 24/7 with 10 RTSP streams: using a separate process to send the message, or using an inbuilt plugin like nvmsgbroker?
nvmsgbroker supports sending Azure IoT broker, you can use the ready-made Deepstream plugin. you can compare the performance yourself since nvmsgbroker plguin and low-level lib are opensource in DS7.1.
