You could check the activation of conda environment.
When you first install the isaacgym, it is recommended to create the conda environment called “rlgpu” using anaconda.
So now that Isaacgym runs on Windows, is there a way to connect the installed module from the Omniverse install to resolve the issue bnefe10 mentions? ie: “ModuleNotFoundError: No module named ‘isaacgym’”
Hi @nospam11
Isaac Gym Preview doesn’t run on Windows
