There is something basic I don’t understand about modules. I want to convert include files that shared data via the old common block structure by changing the files to modules.
Extracted the basic issue to a simple example. If I leave the module in the file with the program and other subroutines, no problem. If I take the module out as a separate file I get the following typical error:
E:\PGI_5-11-2013mod2\Source Files\fall.f90(8) : error F0004 : Corrupt or Old Module file E:\PGI_5-11-2013mod2\Include Files\constants.mod
Could someone suggest what I’m doing wrong please?
module constants
integer, parameter :: np=2000, dbl=selected_real_kind(14,100)
real(dbl) :: g=9.807, dtmin=.001, kspg=10., mass = 100.0
end module constants
program fall
use constants
implicit none
! Program to calculate the dynamics of a falling body
real(dbl), allocatable :: v(:),z(:),t(:), zreal(:)
real(dbl) dt
integer nsteps
allocate (v(np),z(np),t(np),zreal(np))
call input(z,dt)
call odesolve(v,z,t,dt,nsteps)
call realans(t,z,nsteps,zreal)
call output (t,z,zreal,v,nsteps)
stop
end
subroutine input (z,dt)
use constants
implicit none
return
end
subroutine odesolve(v,z,t,dt,nsteps)
use constants
implicit none
real (dbl) v(*),z(*),t(*),dt,c0,c1
integer i,nsteps
return
end
subroutine realans(t,z,nsteps,zreal)
use constants
implicit none
return
end
subroutine output(t,z,zreal,v,nsteps)
use constants, only : dbl
implicit none
return
end
Same problem with either PVF 13.4 or 13.5 using VS2008 in Windows 7 64-bit.
