Hi, I have trouble with running motors with code below on Jetson Nano:
from jetbot import Robot
robot = Robot()
a = 1
while a == 1:
robot.forward(speed=0.4)
print(robot.left_motor.value)
print(robot.right_motor.value)
Code runs without any errors (print output gives “0.4” value), but motors connected to motor-driver don’t work. I also tried to use JetBot examples Examples · NVIDIA-AI-IOT/jetbot Wiki · GitHub but code from basic-motion.ipynb also doesn’t work. I measured voltage on motor connections, but it looks there is no voltage on output.
https://cdn.sparkfun.com/assets/learn_tutorials/5/7/4/FrontAnnotated01.png
I’m using SparkFun JetBot AI Kit with JetPack 4.2.2.
I connected everything as in official guide: Assembly Guide for SparkFun JetBot AI Kit - learn.sparkfun.com
Red LED of ROB-13911 motor-driver is blinking.
I used sudo i2cdetect -y -r 1 and see that motor-driver is under address 0x5d (as in official guide, because of soldered #3 jumper of motor-driver)
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- 3d -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- 5d -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I also changed addres and i2c_bus of motorHat init in ~/Adafruit-Motor-HAT-Python-Library/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py before setup (I did it beacuse of IOError: [Errno 121] Remote I/O error with default address)
def __init__(self, addr = 0x60, freq = 1600, i2c=None, i2c_bus=None):
to:
def __init__(self, addr = 0x5d, freq = 1600, i2c=None, i2c_bus=1):
That allows me to run code, but motors still don’t work, and measured voltage on motor connections is 0 [V].
I also ordered new motor-driver (ROB-13911) but I have still same problem.
Could I ask for help with starting the motors?
