Hi.
Where can I find the API for the mst package (mtcr library)?
I’m fine if you will point me the git project for mst tools like i2c
Hello @dimax.main,
You can refer to the official GitHub repository of the mstflint project, the mstflint project provides tools and libraries for managing and configuring Mellanox devices, including the mst package.
You can find the mstflint project on GitHub using the following link:
Hope this answers your question.
Regards,
Bhargavi
It helped a bit but it has nothing about the mtusb device or i2c access.
Anyway I managed to build my application using WinMFT SDK.
But I still have an issue with opening a mtusb device, although I know that device is connected and mst status can see it:
My application name is sprutm. I placed it into the WinMFT folder. I run command shell as Administrator:
What do you think can be an issue?
I believe it is something with security on Windows.
Let me know if you need more details.
Thanks. Regards.
Hello.
Any updates here? We can not move forward with our development without your help.
App refers to the device linux path.
Try only mtusb-1 without /dev/mst.
Because I still can’t find any reference on how to use MFT package with mtusb-1 I’m not sure that below code is correct:
/* Open device */
mf = mopen( config.mdev );
if( !mf )
failed( errno, "Can't open %s : %s", config.mdev, strerror(errno) );
Also it is strange that errno is not set.
Can you please scan the mtusb device?
mlxi2c -d <mtusb_dev> scan
