Sorry that took so long, was getting SPI and CAN working. Quick fix to the set_format function. I hadn’t filled it out due to hard coding the format for testing.
v4l2-compliance fully passes:
ubuntu@tegra-ubuntu:~$ v4l2-compliance -d /dev/video0
Driver Info:
Driver name : tegra-video
Card type : vi-output-0, daxc02 6-0010
Bus info : platform:vi:0
Driver version: 3.10.96
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 7 Private Controls: 13
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
test VIDIOC_G/S_PARM: OK (Not Supported)
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
fail: v4l2-test-formats.cpp(1486): node->can_scale && node->frmsizes_count[v4l_format_g_pixelformat(&cur)]
test Scaling: OK
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 42, Succeeded: 42, Failed: 0, Warnings: 0
No change to the “No module data found” issue.
ubuntu@tegra-ubuntu:~$ nvgstcapture-1.0
Encoder null, cannot set bitrate!
Encoder Profile = Baseline
Supported resolutions in case of CSI Camera
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Runtime CSI Camera Commands:
Help : 'h'
Quit : 'q'
Set Capture Mode:
mo:<val>
(1): image
(2): video
Get Capture Mode:
gmo
Set Sensor Id (0 to 10):
sid:<val> e.g., sid:2
Get Sensor Id:
gsid
Set sensor orientation:
so:<val>
(0): none
(1): Rotate counter-clockwise 90 degrees
(2): Rotate 180 degrees
(3): Rotate clockwise 90 degrees
Get sensor orientation:
gso
Set Whitebalance Mode:
wb:<val>
(0): off
(1): auto
(2): incandescent
(3): fluorescent
(4): warm-fluorescent
(5): daylight
(6): cloudy-daylight
(7): twilight
(8): shade
(9): manual
Get Whitebalance Mode:
gwb
Set Scene-Mode:
scm:<val>
(0): face-priority
(1): action
(2): portrait
(3): landscape
(4): night
(5): night-portrait
(6): theatre
(7): beach
(8): snow
(9): sunset
(10): steady-photo
(11): fireworks
(12): sports
(13): party
(14): candle-light
(15): barcode
Get Scene-Mode:
gscm
Set Color Effect Mode:
ce:<val>
(1): off
(2): mono
(3): negative
(4): solarize
(5): sepia
(6): posterize
(7): aqua
Get Color Effect Mode:
gce
Set Auto-Exposure Mode:
ae:<val>
(1): off
(2): on
(3): OnAutoFlash
(4): OnAlwaysFlash
(5): OnFlashRedEye
Get Auto-Exposure Mode:
gae
Set Flash Mode:
f:<val>
(0): off
(1): on
(2): torch
(3): auto
Get Flash Mode:
gf
Set Flicker Detection and Avoidance Mode:
fl:<val>
(0): off
(1): 50Hz
(2): 60Hz
(3): auto
Get Flicker Detection and Avoidance Mode:
gfl
Set Contrast (0 to 1):
ct:<val> e.g., ct:0.75
Get Contrast:
gct
Set Saturation (0 to 2):
st:<val> e.g., st:1.25
Get Saturation:
gst
Set Exposure Time in seconds:
ext:<val> e.g., ext:0.033
Get Exposure Time:
gext
Set Auto Exposure Lock(0/1):
ael:<val> e.g., ael:1
Get Auto Exposure Lock:
gael
Set Edge Enhancement (0 to 1):
ee:<val> e.g., ee:0.75
Get Edge Enhancement:
gee
Set ROI for AE:
It needs five values, ROI coordinates(top,left,bottom,right)
and weight in that order
aer:<val> e.g., aer:20 20 400 400 1.2
Get ROI for AE:
gaer
Set ROI for AWB:
wbr:<val> e.g., wbr:20 20 400 400 1.2
Get ROI for AWB:
gwbr
Set FPS range:
It needs two values, FPS Range (low, high) in that order
fpsr:<val> e.g., fpsr:15 30
Get FPS range:
gfpsr
Set WB Gains:
It needs four values (R, GR, GB, B) in that order
wbg:<val> e.g., wbg:1.2 2.2 0.8 1.6
Get WB Gains:
gwbg
Set TNR Strength (0 to 1):
ts:<val> e.g., ts:0.75
Get TNR Strength:
gts
Set TNR Mode:
tnr:<val>
(0): NoiseReduction_Off
(1): NoiseReduction_Fast
(2): NoiseReduction_HighQuality
Get TNR Mode:
gtnr
Capture: enter 'j' OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter '1'
Stop Recording : enter '0'
Video snapshot : enter '2' (While recording video)
Set Preview Resolution:
pcr:<val> e.g., pcr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Note - For preview resolutions 4208x3120 and more use option --svs=nveglglessink
Get Preview Resolution:
gpcr
Set Image Resolution:
icr:<val> e.g., icr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Get Image Capture Resolution:
gicr
Set Video Resolution:
vcr:<val> e.g., vcr:3
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
Get Video Capture Resolution:
gvcr
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br:<val> e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep:<val> e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter 'f'
bitrate = 4000000
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingSocket read error. Camera Daemon stopped functioning.....
gst_nvcamera_open() failed ret=0
** (nvgstcapture-1.0:1996): CRITICAL **: <create_capture_pipeline:4399> can't set camera to playing
** (nvgstcapture-1.0:1996): CRITICAL **: <main:5187> Capture Pipeline creation failed
** Message: <main:5194> Capture completed
** Message: <main:5244> Camera application will now exit
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
Sensor_CheckDriverVersion: Mixed or missing V4L2 controls!
Sensor_CheckDriverVersion: Make sure your kernel driver implements either
Sensor_CheckDriverVersion: V4L2_CID_FRAME_LENGTH + V4L2_CID_COARSE_TIME(_SHORT)
Sensor_CheckDriverVersion: or
Sensor_CheckDriverVersion: V4L2_CID_FRAME_RATE + V4L2_CID_EXPOSURE
Sensor_InitializeV4L2Items: Failure ------------
NvPclDriver_V4L2_Sensor_Initialize: Failure ---------------------
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 121)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 516)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 702)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 263)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 422)
./debug_daemon.sh: line 6: 1933 Segmentation fault sudo /usr/sbin/nvcamera-daemon
compliance.txt (2.65 KB)
