I have a Ryzen WRX80 / 3975WX / 256 GB RAM / 1600W PSU workstation that I use for both work and gaming. Setup consists of 3 x P620 (one of them is of newer model) and RTX 3060Ti:
- 8 x Dell P2419H monitors connected to the old P620
- LG 43UD79-B connected to the new P620
- LG 38WN95C-W connected to RTX 3060 Ti
All using Native Display Port cables, no conversion what so ever.
Issues:
-Despite the fact that I am running a behemoth of a computer, Windows Desktop Manager rendering sometimes become sluggesh and the mouse lags while moving the cursor around. I have tried setting refresh rate all the same as well as color settings. still slow, this is an intermittent issue mostly noticible if I right click → display settings in windows or try and open nvidia control panel.
-The issue is more sever if a monitor that is hookedup to a P620 is made the primary display (not sure how windows rendering works, does throw rendering of all displays to a single GPU ?)
-The monitor hooked up to the first port of each of the Quadro P620 would not sleep if I disconnect the monitor from Windows settings (i.e. i opt not to use it and ask windows to ignore it). I use DC2.exe because the windows display manager sucks big time when it comes to arranging monitors to the pixel level. Having said that, if I say wanted to game, i switch to a configuration where only the gaming monitor is used and the rest are disconnected by windows. All displays will sleep except the ones hookedup to Port 1 of the Quadros.
-I’ve noticed the newer model of the Quadro has a slightly newer BIOS. Do I need to bring all the Quadros to the same FW level and how?
Below System info captured from Nvidia Control Panel:
NVIDIA System Information report created on: 01/16/2022 22:37:40
System name: MESHX86-RYZEN
[Display]
Operating System: Windows 10 Enterprise, 64-bit
DirectX version: 12.0
GPU processor: Quadro P620
Driver version: 497.29
Driver Type: DCH
Direct3D feature level: 12_1
CUDA Cores: 512
Core clock: 1265 MHz
Memory data rate: 5.01 Gbps
Memory interface: 128-bit
Memory bandwidth: 80.16 GB/s
Total available graphics memory: 133039 MB
Dedicated video memory: 2048 MB GDDR5
System video memory: 0 MB
Shared system memory: 130991 MB
Video BIOS version: 86.07.90.00.A7
IRQ: Not used
Bus: PCI Express x16 Gen3
Device Id: 10DE 1CB6 126410DE
Part Number: G178 0505
Driver Type: DCH
CUDA Cores: 512
Video BIOS version: 86.07.71.00.01
IRQ: Not used
Part Number: G212 0505
Driver Type: DCH
CUDA Cores: 512
IRQ: Not used
GPU processor: NVIDIA GeForce RTX 3060 Ti
Driver Type: DCH
CUDA Cores: 4864
Resizable BAR No
Core clock: 1740 MHz
Memory data rate: 14.00 Gbps
Memory interface: 256-bit
Memory bandwidth: 448.06 GB/s
Total available graphics memory: 139183 MB
Dedicated video memory: 8192 MB GDDR6
Video BIOS version: 94.04.27.40.B4
IRQ: Not used
Bus: PCI Express x16 Gen4
Device Id: 10DE 2486 405A1458
Part Number: G190 0010
[Components]
nvui.dll 8.17.14.9729 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.14.9729 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.14.9729 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.14.9729 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.14.9729 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.940.0 NVIDIA Control Panel
nvCplUI.exe 8.1.940.0 NVIDIA Control Panel
nvWSSR.dll 30.0.14.9729 NVIDIA Workstation Server
nvWSS.dll 30.0.14.9729 NVIDIA Workstation Server
nvViTvSR.dll 30.0.14.9729 NVIDIA Video Server
nvViTvS.dll 30.0.14.9729 NVIDIA Video Server
nvLicensingS.dll 6.14.14.9729 NVIDIA Licensing Server
nvDevToolSR.dll 30.0.14.9729 NVIDIA Licensing Server
nvDevToolS.dll 30.0.14.9729 NVIDIA 3D Settings Server
nvDispSR.dll 30.0.14.9729 NVIDIA Display Server
nvDispS.dll 30.0.14.9729 NVIDIA Display Server
PhysX 09.21.0713 NVIDIA PhysX
NVCUDA64.DLL 30.0.14.9729 NVIDIA CUDA 11.5.125 driver
nvGameSR.dll 30.0.14.9729 NVIDIA 3D Settings Server
nvGameS.dll 30.0.14.9729 NVIDIA 3D Settings Server
