I’m running the deepstream-app on an mp4 file and it works fine with one source. However whenI define a second source with a different mp4 file this is the output I get and the app seems to run forever
**PERF: FPS 0 (Avg) FPS 1 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00)
I have followed the instructions to run deepstream with multiple sources so I’m not quite sure what is going on. Has someone had this kind of problem ? Any help much appreciated.
Many thanks,
Stephane
Below is my config file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=2
uri=file:///dfs/video/take37/camera15/2018-10-04-00000-00130.mp4
num-sources=1
cudadec-memtype=0
gpu-id=0
[source1]
enable=1
type=2
uri=file:///dfs/video/take37/camera16/2018-10-04-00000-00130.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=3
container=1
codec=3
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
output-file=/dfs/output/td_stream_output_test2.mp4
source-id=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
only SW mpeg4 is supported right now.
codec=3
sync=0
#iframeinterval=10
bitrate=2000000
output-file=/dfs/output/td_stream_output_test.mp4
source-id=1
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=400000
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=0
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.0;0.0;0.0;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=2
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=0
Set muxer output width and height
width=1280
height=720
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
config-file=config_mux_source4.txt
gpu-id=0
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b4_int8.engine
labelfile-path=../../models/Primary_Detector/labels.txt
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=1
tracker-width=600
tracker-height=300
#ll-lib-file=/usr/local/deepstream/libnvds_mot_iou.so
ll-lib-file=/usr/local/deepstream/libnvds_mot_klt.so
#ll-config-file required for IOU only
#ll-config-file=iou_config.txt
gpu-id=0
[secondary-gie0]
enable=0
model-engine-file=../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.engine
labelfile-path=../../models/Secondary_VehicleTypes/labels.txt
gpu-id=0
batch-size=2
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_vehicletypes.txt
[secondary-gie1]
enable=1
model-engine-file=../../models/Secondary_CarColor/resnet18.caffemodel_b16_int8.engine
labelfile-path=../../models/Secondary_CarColor/labels.txt
batch-size=2
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_secondary_carcolor.txt
[tests]
file-loop=0
