I have two RTSP sources and both on them are connected after a while the second source will stop processing without appearing or writing any error to know reason of stop processing.
Attached sample of multi-steam initialization sample.py (11.7 KB).
Why the second source stop processing and the RTSP itself is connected?
Could you attach the log with GST_DEBUG=3 and update your deepstream to the latest version?
Also, you should set the is_live to true before set the streammux live-source para in your code.
I change is_live to true and run the system with GST_DEBUG mode for more than 8 hours. During this the system restart 7 times and appear these errors; error.txt (928 Bytes)
From the log analysis, your source may generate abnormal video frames.
About the logic of reconnection, you can refer to our open source: sources\apps\apps-common\src\deepstream_source_bin.c check_rtsp_reconnection_attempts
Their is no issue from my RTSP source cause when I try a single stream their is no issue but when I try it with multi-streams (2 streams) appear all these issue.
Why multi-stream in deepstream not stable what is the issue??
