I need to have two input RTSP streams to Deepstream 5.0. Is it possible to have two streams with two different port numbers?
Thank you.
Thank you.
Surely, two streams with two different port numbers can be supported. DeepStream is based on gstreamer, gstreamer rtsp elements rtspsrc (gstreamer.freedesktop.org) are implemented based on RTSP spec RFC 2326 - Real Time Streaming Protocol (RTSP) (ietf.org). Please refer to RTSP URL part RFC 2326 - Real Time Streaming Protocol (RTSP) (ietf.org) in RFC2326, the rtsp url has already support different port for different rtsp streams.
Before you use rtsp, you need to know basic knowledge of it.
Thank you, I was able to run multiple RTSP streams.
