• Hardware Platform (Jetson TX2)
• DeepStream Version 4.0
• JetPack Version ( 4.2.1)
• TensorRT Version ( 6.0)
When i run two deepstream config file at the same time using
for example
deepstream-app -c conf_file.txt
while enabling RTSP stream for the two config file with different port number
,when i view the rtsp stream of one of the two RTSP stream using the port number of this stream i get frames from the two RTSP stream at the same time mixed up . How i can solve that so i can view the two stream independently?
