Goodmorning,
I’m using JetPack 3.2 and trying to modify the config file (PGIE-FP16-CarType-CarMake-CarColor.txt) into the DeepStream folder (subdirectory configs) to display 4 RTSP video streams, in particular, coming from videocams in the network
In the visualization of a single video stream I had no problems.
I start to have it when it comes to multiple video streams (coming from different sources RSTP).
[source0]
enable=1
type=3
uri=<first RTSP>
[source1]
enable=1
type=3
uri=<second RTSP>
[source2]
enable=1
type=3
uri=<third RTSP>
[source3]
enable=1
type=3
uri=<fourth RTSP>
Currently I am trying to operate on the source-id field of the sink group but without success: even specifying the correct source id, it does not work (i’m using a 1920x1080 monitor)
[sink0]
enable=1
type=3
offset-x=0
offset-y=0
width=960
height=540
sync=1
source-id=0
[sink1]
enable=1
type=3
offset-x=960
offset-y=0
width=960
height=540
sync=1
source-id=1
[sink2]
enable=1
type=3
offset-x=0
offset-y=540
width=960
height=540
sync=1
source-id=2
[sink3]
enable=1
type=3
offset-x=960
offset-y=540
width=960
height=540
sync=1
source-id=3
In particular, the viewing windows of the streams are opened (up to 2) but either you see only the first source or the frames of the selected sources are mixed between the windows
I’m using the basic nvgstiva-app (sudo rm -rf ${HOME}/.cache/* && nvgstiva-app -c /home/nvidia/configs/myconfigfile.txt)
Someone can help me?
Thank you for your help
