Multi rtsp steam out in same port
how to get multi rtsp steam out like http://192.168.3.111:8554/ds-test and http://192.168.3.111:8554/ds-test1
please provide an example with config.txt
below not work
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
square-seq-grid=1
[source0]
enable=1
type=3
uri=file:///tmp/card_video_files/00000000063000000.mp4
num-sources=1
gpu-id=0
#drop-frame-interval=5
cudadec-memtype=0
[source1]
enable=1
type=3
uri=file:///tmp/card_video_files/00000000064000000.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=0
gpu-id=0
qos=1
nvbuf-memory-type=0
[sink1]
enable=1
type=4
codec=1
enc-type=0
sync=0
qos=1
source-id=0
bitrate=4000000
profile=0
rtsp-port=8554
udp-port=5400
width=1920
height=1080
[sink2]
enable=1
type=4
codec=1
enc-type=0
sync=0
qos=1
source-id=1
bitrate=4000000
profile=0
rtsp-port=8555
udp-port=5400
width=1920
height=1080
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=2
batched-push-timeout=40000
width=2560
height=1440
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV8.txt
[tests]
file-loop=0
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0 in docker
• TensorRT Version
deepstream-app is opensource. ds-test is hardcoded in start_rtsp_streaming of \opt\nvidia\deepstream\deepstream\sources\apps\apps-common\src\deepstream_sink_bin.c. you can modify it to customize.
how multi rtsp stream out with different factory and same port?
you can create multiple gst_rtsp_server_new with different port. please refer to start_rtsp_streaming for rtsp server is set.
python has an example?
please refer to this python code. you can create multiple GstRtspServer.RTSPServer.new().
