I’m developing multiple cameras application with Jetson Xavier DV kit.
the goal is to implement real time image processing (such as panoramic stitching).
Since I’m using three of 4K cameras, it is little bit hard to get this performance.
having a time for optimization with one board, I’m wondering if there is an option to use multiple Jetson boards.
Do you want to mount multiple camera on a single Xavier(ex. master) or separate them on several boards?
One key problem of stitching is synchronization.
Suppose you expect to have the three 4K image at the same time, mount camera in different device will make it more challenge.
If the synchronized issue can be overcome, to leverage the computing power of other Jetson is possible.
But expected there is some transmission overhead which will reflect on latency.
Thank you AastaLLL.
regarding encoding specification, sychronization, Let’s say I will connect multiple cameras on master Jetson, and encoding will be panoramic video resized to 4K resolution.
the purpose is to process it in real-time, and if there is enough resources left, there will be more functions.
" leverage the computing power of other Jetson is possible "
How can I get some information regarding this topic?
Can I just use Jetson Xavier DV kit + Jetson board(without other kit?
or should be Dual Jetson Xavier DV kit?
2.
The problem is that the maximal decode/encode power of a single Xavier is 2x4Kp60.
The performance of 3x4Kp60 camera on a single Xavier is not guaranteed.
