I run a 2-year old program from github which only works with Python 3.7 (does not work with Python 3.8, 3.9, 3.10) and uses tensorflow , torch, spacy all with GPU support and many other modules. I was able to run the program ok without GPU. Without GPU hardware, with torch=1.13.1 and TF=2.9.0 it gives warnings that CUDA is not available, but otherwise runs without errors and does produce correct results.
I spent a week trying to make it work with GPU. With Python 3.7, TF is upper-limited to Cuda=11.2 and Cudnn=8.1, yet there is no torch+cu112. It means I have to have two different versions of Cuda at the same time.
conda install -c conda-forge cudatoolkit=11.2.2 cudnn=8.1.0 # for TF and Spacy
pip install spacy[cuda112]
pip install torch==1.12.1+cu113 torchvision==0.13.1+cu113 torchaudio==0.12.1 --extra-index-url https://download.pytorch.org/whl/cu113
`(py37) $ python -c “import torch; print(f’PyTorch version {torch.version} has CUDA : {torch.cuda.is_available()}')”
PyTorch version 1.12.1+cu113 has CUDA : True’
When I run the program, depending on torch+cuda version, I get various torch errors. For example:
RuntimeError: CUDA out of memory. Tried to allocate 148.00 MiB (GPU 0; 15.71 GiB total capacity; 1.33 GiB already allocated; 50.50 MiB free; 1.45 GiB reserved in total by PyTorch) If reserved memory is >> allocated memory try setting max_split_size_mb to avoid fragmentation. See documentation for Memory Management and PYTORCH_CUDA_ALLOC_CONF
In addition to torch==1.12.1+cu113, I tried other torch+cuda versions. Some of them install ok and appear to recognize my GPU ok, but all fail with various torch errors when I run the program.
I am aware that Python 3.7 is no longer officially supported yet hope to get GPU to work. Is running without GPU my only option?
Is it in principle a good idea to run side by side different (multiple) versions of Cuda? Would I be better off if running a single Cuda version 11.0 with Cudnn 8.0 for both TF and torch (and spacy)?
conda install -c conda-forge -c nvidia cudatoolkit=11.0 cudnn=8.0 # for TF and Spacy
pip install spacy[cuda110]
pip install torch==1.*+cu110 torchvision==*+cu110 torchaudio==* --extra-index-url https://download.pytorch.org/whl/cu110
Collecting environment information…
PyTorch version: 1.12.1+cu113
CUDA used to build PyTorch: 11.3
ROCM used to build PyTorch: N/A
OS: Ubuntu 22.04.3 LTS (x86_64)
GCC version: (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Libc version: glibc-2.10
Python version: 3.7.12 | packaged by conda-forge | (default, Oct 26 2021, 06:08:21) [GCC 9.4.0] (64-bit runtime)
Python platform: Linux-6.2.0-36-generic-x86_64-with-debian-bookworm-sid
Is CUDA available: True
CUDA runtime version: Could not collect
CUDA_MODULE_LOADING set to:
GPU models and configuration: GPU 0: NVIDIA GeForce RTX 4060 Ti=16Gb
Nvidia driver version: 535.129.03
cuDNN version: Could not collect
Is XNNPACK available: True
CPU:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 46 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 24
On-line CPU(s) list: 0-23
Vendor ID: GenuineIntel
Model name: 12th Gen Intel(R) Core™ i9-12900K
CPU family: 6
Model: 151
Thread(s) per core: 2
Core(s) per socket: 16
Socket(s): 1
Stepping: 2
CPU max MHz: 5200.0000
CPU min MHz: 800.0000
BogoMIPS: 6374.40
Virtualization: VT-x
L1d cache: 640 KiB (16 instances)
L1i cache: 768 KiB (16 instances)
L2 cache: 14 MiB (10 instances)
L3 cache: 30 MiB (1 instance)
NUMA node(s): 1
NUMA node0 CPU(s): 0-23
Versions of relevant libraries:
[pip3] numpy==1.21.6
[pip3] torch==1.12.1+cu113
[pip3] torchaudio==0.12.1+cu113
[pip3] torchvision==0.13.1+cu113
[conda] cudatoolkit 11.2.2 hc23eb0c_12 conda-forge
[conda] numpy 1.21.6 pypi_0 pypi
[conda] torch 1.12.1+cu113 pypi_0 pypi
[conda] torchaudio 0.12.1+cu113 pypi_0 pypi
[conda] torchvision 0.13.1+cu113 pypi_0 pypi
