I am trying to optimize mxnet models using it’s contrib.tensorrt module. I am following this tutorial: https://mxnet.apache.org/api/python/docs/tutorials/performance/backend/tensorrt/tensorrt.
However, the following line causes an error:
trt_sym = sym.get_backend_symbol('TensorRT')
Error:
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/mxnet/symbol/symbol.py", line 2717, in get_backend_symbol
check_call(_LIB.MXGenBackendSubgraph(self.handle, c_str(backend), ctypes.byref(out)))
File "/usr/local/lib/python3.6/dist-packages/mxnet/base.py", line 255, in check_call
raise MXNetError(py_str(_LIB.MXGetLastError()))
mxnet.base.MXNetError: [15:07:42] src/c_api/../operator/subgraph/subgraph_property.h:502: Check failed: it != backend_map_.end(): SubgraphProperty TensorRt is not found in SubgraphBackendRegistry
Stack trace:
[bt] (0) /usr/local/mxnet/libmxnet.so(dmlc::LogMessageFatal::~LogMessageFatal()+0x4c) [0x7f7662eebc]
[bt] (1) /usr/local/mxnet/libmxnet.so(mxnet::op::SubgraphBackendRegistry::GetSubgraphBackend(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)+0x150) [0x7f79b80268]
[bt] (2) /usr/local/mxnet/libmxnet.so(MXGenBackendSubgraph+0xf8) [0x7f79b78750]
[bt] (3) /usr/lib/aarch64-linux-gnu/libffi.so.6(ffi_call_SYSV+0x64) [0x7fa83bfd28]
[bt] (4) /usr/lib/aarch64-linux-gnu/libffi.so.6(ffi_call+0xc8) [0x7fa83c0698]
[bt] (5) /usr/lib/python3.6/lib-dynload/_ctypes.cpython-36m-aarch64-linux-gnu.so(_ctypes_callproc+0x41c) [0x7fa83e31ac]
[bt] (6) /usr/lib/python3.6/lib-dynload/_ctypes.cpython-36m-aarch64-linux-gnu.so(+0x104c0) [0x7fa83e34c0]
[bt] (7) python3(_PyObject_FastCallDict+0xd0) [0x6057e0]
[bt] (8) python3() [0x529738]
I am using mxnet 1.6 installed from the precompiled wheel. (https://devtalk.nvidia.com/default/topic/1070767/jetson-nano/i-was-unable-to-compile-and-install-mxnet1-5-with-tensorrt-on-the-jetson-nano-is-there-someone-have-compile-it-please-help-me-thank-you-/post/5426042/#5426042)
It seems that this error is caused because this wheel was not build with the USE_TENSORRT option. I tried to compile mxnet from source with the USE_TENSORRT option but it asks for cmake version 3.13, and the latest in jetson Xavier is 3.10.
