hi
When using jps, I found that VIC was not used, but when I used the example of deepstream-test5, I used the configuration of ai_nvr, but found that VIC was used. Please help me to see how to configure it so as not to use VIC, because there are bugs in VIC introduced in the document.
The official documentation only refers to ds-config-0_agx.yaml, but does not specify which configuration fields are used
