I’m flashing my Xavier AGX with SDK Manager ,but some issues occured.First,SDK Manager recognized it as Xavier NX when I change moudle into recover mode.Second,the USB device was removed ,when I clicked the “Flash” of the pop-up in step03.One second later,the USB device was added.But an error occured,and flashing failed.
Following pictures are the flashing process:
And then,I try to flash my moudle with L4T mode,the version is “JetPack-L4T-4.1.1-linux-x64_b57.run”.
But fanlly,it didn’t work,an error occured,and flashing failed.
Look forward to someone’s help.Thank you!
It is my first time seeing such “AGX recognized as NX” issue.
Is this device still able to boot up?
BTW, I don’t get your purpose to use such old jetpack release to flash… please do not use this anymore.
Yesterday,it runned well as usual.Today, it’s always restarting, since I copy a new dtb document into module and refresh the extlinux.conf. But it still can enter bootloader shell mode,when I stop autoroot process through uart debugging.
---- Replied Message ----
From | WayneWWW via NVIDIA Developer Forumsnotifications@nvidia.discoursemail.com |
Date | 03/31/2023 20:58 |
To | g_shilong@163.com |
Cc | |
Subject | [NVIDIA Developer Forums] [Jetson & Embedded Systems/Jetson AGX Xavier] My Xavier AGX is recognized as Xavier NX by SDK Manager |
| WayneWWW Moderator
March 31 |
Please manually use flash.sh to flash instead of sdkmanager.
OK,thanks for your suggestion.
After flashing with the latest version,it doesn’t boot up.Following pictures are my flashing steps:
It seems no fault during my flashing steps.But still fail in the end.
Then,I try to flash .img to myAGX with ./flash -r …,but some new issue happen.
please attach full text log. Are we sure the disk space there is really sufficient?
flashing.txt (44.4 KB)
Yes,total 32GB.System can’t be that big.
Could you share the result of df -h on your host?
I change another computer to flash again,details as this txt.
flashing-2.txt (71.1 KB)
please dump the serial console log from UART during this flash error and share it.
Hello @g_shilong
Is it an 8GB AGX Xavier?
yes,it is.
From | mehmetdeniz via NVIDIA Developer Forumsnotifications@nvidia.discoursemail.com |
Date | 04/04/2023 20:12 |
Cc | |
| mehmetdeniz
April 4 |
Hello @g_shilong
please also use jp4.6.3 to flash it instead of jp5.
ok,thank you.I’ll try again when I back to company.
Date | 04/04/2023 20:16 |
Cc | |
| WayneWWW Moderator
April 4 |
flashing-4.txt (56.5 KB)
The same error happens in flashing with jetpack4.6.3.
This is UART log for booting up AGX after fail in flashing.
session5.log (26.8 KB)
If this is AGX Xavier 8GB, please download rel-32.4.3 and try to flash it.
Yes,it is,and I have tried again with rel-32.4.3 just now,but still fail.
flashing-5.txt (39.9 KB)
