Hello, teams.
We have occasional boot failure on out Jetson Nano platform, which looks similar to the topic below:
The `dying’ console is the following, and it looks similar to the above mentioned topic. (Stops just after ther thernal* messages)
The original topic is already `closed’ after some questions about DVFS features.
Does anyone has a similar issue? or Any further information?
Did DVFS tweaks worked?
Thanks in advance
------------------ from here ----------------
[ 3.207563] [drm] Initialized
[ 3.236875] brd: module loaded
[ 3.244722] tegradc tegradc.0: fb registered
[ 3.250060] loop: module loaded
[ 3.250816] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 3.250890] tegradc tegradc.1: No lt-data, using default setting
[ 3.250914] tegradc tegradc.1: No hpd-gpio in DT
[ 3.250945] tegradc tegradc.1: DT parsed successfully
[ 3.250997] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 3.252341] tegradc tegradc.1: dpd enable lookup fail:-19
[ 3.757970] Host read timeout at address 545c00c4
[ 3.759101] tegradc tegradc.1: probed
[ 3.796771] tegradc tegradc.1: fb registered
[ 3.796908] tegra_profiler: version: 1.134, samples/io: 47/26
[ 3.797048] tegra_profiler: auth: init
[ 3.798329] THERMAL EST: found 2 subdevs
[ 3.798335] THERMAL EST num_resources: 0
[ 3.798340] [THERMAL EST subdev 0]
[ 3.798348] [THERMAL EST subdev 1]
[ 3.798827] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.798829] THERMAL EST: thz register success.
[ 3.799002] THERMAL EST: end of probe, return err: 0
[ 3.800218] hisi_sas: driver version v1.6
[ 3.806709] libphy: Fixed MDIO Bus: probed
