I have followed the instruction on the Jetson Nano “getting started” page to flash a UHS-1 SD card. However, the nano is not booting. I am using the DC barrel port for power and have tried two different cards.
It appears from the serial log that things get lost during the handoff from the bootloader to kernel.
Any ideas of what is going wrong?
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1d20e2
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.448] Csd NumOfBlocks=249737216
[0000.508] Using GPT Primary to query partitions
[0000.518] Loading Tboot-CPU binary
[0000.895] Verifying TBC in OdmNonSecureSBK mode
[0000.905] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.912] Bootloader downloaded successfully.
[0000.916] Downloaded Tboot-CPU binary to 0xa0000258
[0000.921] MAX77620_GPIO5 configured
[0000.924] CPU power rail is up
[0000.927] CPU clock enabled
[0000.931] Performing RAM repair
[0000.934] Updating A64 Warmreset Address to 0xa00002e9
[0000.939] Loading NvTbootBootloaderDTB
[0002.250] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.312] Bootloader DTB Load Address: 0x83000000
[0002.316] Loading NvTbootKernelDTB
[0003.627] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.689] Kernel DTB Load Address: 0x83100000
[0003.699] Loading cboot binary
[0005.380] Verifying EBT in OdmNonSecureSBK mode
[0005.422] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0005.429] Bootloader downloaded successfully.
[0005.623] Using BFS PT to query partitions
[0005.627] Next binary entry address: 0x92c00258
[0005.632] BoardId: 3448
[0005.636] Overriding pmu board id with proc board id
[0005.641] Display board id is not available
[0007.139] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.193] /bpmp deleted
[0007.195] SC7EntryFw header found loaded at 0xff700000
[0007.386] OVR2 PMIC
[0007.388] Bpmp FW successfully loaded
[0007.406] WB0 init successfully at 0xff780000
[0007.410] Set NvDecSticky Bits
[0007.414] GSC2 address ff53fffc value c0edbbcc
[0007.420] GSC MC Settings done
[0007.428] TOS Image length 53680
[0007.431] Monitor size 53680
[0007.433] OS size 0
[0007.596] Secure Os AES-CMAC Verification Success!
[0007.601] TOS image cipher info: plaintext
[0007.605] Loading and Validation of Secure OS Successful
[0007.621] SC7 Entry Firmware - 0xff700000, 0x4000
[0007.625] NvTbootPackSdramParams: start.
[0007.630] NvTbootPackSdramParams: done.
[0007.634] Tegraboot started after 53276 us
[0007.638] Basic modules init took 5728184 us
[0007.642] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0007.647] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0007.653] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0007.658] Storage Device Read Time = 6749 ms, Read Size = 2306 KB
[0007.664] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0007.670] Next stage binary read took 1529711 us
[0007.674] Carveout took -1541391 us
[0007.678] CPU initialization took 2048088 us
[0007.682] Total time taken by TegraBoot 7764592 us
[0007.687] Starting CPU & Halting co-processor
