[0142.414] BoardId read from EEPROM/NCT: 0
This is abnormal.
- Could you share what device did you choose to flash in sdkmanager?
- Have you ever successfully flashed your board before? Not including the sdcard image with Etcher.
This is abnormal.
I select:
Jetson Nano (Developer Kit version)
(P3448)
Previously I was able to flash, first with etcher and then with the SDK Manager.
Not including the sdcard image with Etcher. Only want to know the result of sdkmanager.
Due to an error I think I just confirmed that is a HW issue, I wanted to start from scratch then I took out the SD card from the dev kit to format it, I start the process again but I forgot to put the SD card again on the dev kit and I have the same output on the minicom.
Does the Nano bring any warranty?. because I bought it in July last year.
This is the first time I try to flash directly with SDK Manager, according to the instructions on the documentation of Nano I had to use etcher
Is there a way to fix this?
Sorry that I am a software engineer here so not sure about the warranty. Please check the information of below page.
what is the issue?
I. are you not able to write the image to the sdcard? with etcher? from another computer?
if so, did you try some other sdcard?
II. are you not been able to flash the nano from the sdkmanager?
if so did you try different sdcard?
what power source do you use?
With low power, there might be issues of various kinds with nano unless you are using a redundant power supply.
NO, I’m able to flash the Nano with Etcher, but nano does not boot, seems that the SD card cannot be read. I cannot flash with SDK Manager due the same point.
I already try with several SD Cards and the issue is the same. I have a power source of 5V and 4A.
