njlw
May 5, 2020, 5:02am
#1
Nano jetpak4.2.2 , in tegra_multimedia_api, 00_video_decode, NvDdkVicConfigure Failed.
root@jp422:/home/nano/tegra_multimedia_api-bak/samples/00_video_decode# ./video_decode H264 -ww 1920 -wh 1088 --input-chunks --disable-rendering -o 1.yuv rtsp.264
No protocol specified
nvbuf_utils: Could not get EGL display connection
Set governor to performance before enabling profiler
Creating decoder in blocking mode
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Setting frame input mode to 1
Starting decoder capture loop thread
Input file read complete
Video Resolution: 704x576
Decoder colorspace ITU-R BT.709 with extended range luma (0-255)
libv4l2_nvvidconv (0):(802) (INFO) : Allocating (11) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (0):(818) (INFO) : Allocating (11) CAPTURE PLANE BUFFERS Layout=0
Query and set capture successful
liuwen <<<<<func[dec_capture_loop_fcn] LINE[933]
libv4l2_nvvidconv (0):(1688) (ERROR) : NvDdkVicConfigure Failed
libv4l2_nvvidconv (0):(1710) (ERROR) : NVVIDCONV ERROR 2
njlw
May 5, 2020, 5:03am
#2
which jetpak version is reliable ???
njlw
May 5, 2020, 5:07am
#3
rtsp.264.log (1.3 MB)
rename rtsp.264.log to rtsp.264
Duplicate of
hello , I have a problem about decoding frame in Nano,the solution is 1080p,when I run 00_video_decode.cpp of tegra_multimedia_api samples ,the error is nvDdkVicConfigure Failed,nvbuffer_transform Failed,Transform failed,
Howd Can I Solve It!!
Please install system image and all SDK components through SDKManager.
njlw
May 5, 2020, 7:13am
#7
i have install jetpak4.2.2 from sdk manager
The samples are in
/usr/src/jetson_multimedia_api/samples/00_video_decode/
Please try
If you correctly install the samples through SDKManager, you should be able to successfully run the commands:
nvidia@nvidia-desktop:/usr/src/jetson_multimedia_api/samples/00_video_decode$ export DISPLAY=:0
nvidia@nvidia-desktop:/usr/src/jetson_multimedia_api/samples/00_video_decode$ ./video_decode H264 ../../data/Video/sample_outdoor_car_1080p_10fps.h264
njlw
May 5, 2020, 7:46am
#9
root@jp422:/home/nano/tegra_multimedia_api-bak/samples/00_video_decode# ./video_decode H264 --disable-rendering …/…/data/Video/sample_outdoor_car_1080p_10fps.h264
Video Resolution: 1920x1080
Decoder colorspace ITU-R BT.601 with standard range luma (16-235)
Exiting decoder capture loop thread
App run was successful
njlw
May 5, 2020, 7:51am
#10
the video file from official is ok, but my h264 video file is failed,
Please check if you flash correct image to your Jetson Nano. We have developer Kit version and production module. Although it runs successfully in decoding sample_outdoor_car_1080p_10fps.h264, the error is not expected.
If you have confirmed the image is correct, it is more like an issue in hardware. Probably the board is broken.
njlw
May 5, 2020, 9:07am
#12
DaneLLL:
board
the board: nano + tf card. system install and run in tf card.
you doubt something is wrong with the board? but the nano board just run 2 days.
njlw
May 10, 2020, 3:23am
#13
excuse me, how to solve it ?
it works ok in USE_NVBUF_TRANSFORM_API mode
but if do not use this mode, then error.
We are not able to reproduce the error. By default we use NvBuffer APIs and it is defined in video_decode.h :
#define USE_NVBUF_TRANSFORM_API
Suggest you use NvBuffer APIs.
