I try to run the following example on my Jetson nano production module:
https://docs.nvidia.com/jetson/l4t-multimedia/l4t_mm_00_video_decode.html
Unfortunately the following errors occurred when I execute the following:
chris@chris-desktop:/usr/src/jetson_multimedia_api/samples/00_video_decode$ ./video_decode H264 ./test.h264
No protocol specified
nvbuf_utils: Could not get EGL display connection
Set governor to performance before enabling profiler
Creating decoder in blocking mode
Opening in BLOCKING MODE
Error opening input file
App run failed
The Jetson nano is connected to two cameras that are listed below:
chris@chris-desktop:/usr/src/jetson_multimedia_api/samples/00_video_decode$ v4l2-ctl --list-devices
vi-output, vc_mipi 6-001a (platform:54080000.vi:0):
/dev/video0
vi-output, vc_mipi 0-001a (platform:54080000.vi:2):
/dev/video1
What am I doing wrong? Did anybody had the same error?
The sample uses NvEglRenderer and you would need to set $ export DISPLAY=:0(or 1) . Please set this and give it a try.
I set the environment variable DISPLAY=:1 and the protocol error is fixed. But have received another error:
chris@chris-desktop:/usr/src/jetson_multimedia_api/samples/00_video_decode$ export DISPLAY=:1
App run failed
I tried to solve it by installing the following but the error still occurs
sudo apt-get install cpufrequtils
echo 'GOVERNOR="performance"' | sudo tee /etc/default/cpufrequtils
sudo systemctl disable ondemand
What am I doing still wrong?
hech10311:
It looks like the path to the file is not correct.
thank you for your help. It works, the path was not correct.
