I am having an interesting problem where a Nano will run for days when connected to a keyboard, monitor and mouse, but will shutdown at what appears to be random times when in headless mode. It will even shutdown with an active jupyter lab session. It does not seem to be an out memory issue. I have gone in through Gnome desktop and disabled the various sleep settings. The Nano has both a hardwired ethernet and WiFi connection. I created the sd image manually using the Nvidia instructions. I am using the 4A power supply from Adafruit :) Not a thermal issues - tried with fanon and then off… All of the jupyter lab applications run just fine and I have even developed some of my own code to control a Tello drone…
Any help would be greatly appreciated!
I am not a Linux expert but have looked through the syslog and kern.log files.
Here is the excerpt from the kern.log right when the system shuts down (mac address removed):
May 24 04:51:58 jetpack-dev-desktop kernel: [21053.870835] wlan0: denied authentication (status 37)
May 24 04:52:09 jetpack-dev-desktop kernel: [21064.875794] wlan0: authenticate with
May 24 04:52:09 jetpack-dev-desktop kernel: [21064.884962] wlan0: send auth to (try 1/3)
May 24 04:52:09 jetpack-dev-desktop kernel: [21064.890234] wlan0: denied authentication (status 37)
May 24 04:52:22 jetpack-dev-desktop kernel: [21077.811001] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
May 24 04:52:23 jetpack-dev-desktop kernel: [21078.850868] wlan0: authenticate with
May 24 04:52:23 jetpack-dev-desktop kernel: [21078.859086] wlan0: send auth to (try 1/3)
May 24 04:52:23 jetpack-dev-desktop kernel: [21078.861888] wlan0: denied authentication (status 37)
^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] Booting Linux on physical CPU 0x0
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:47:42 PST 2019
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] Boot CPU: AArch64 Processor [411fd071]
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: fdt: - 80000000 , 7ee00000
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: fdt: - 100000000 , 7f200000
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] On node 0 totalpages: 1039872
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] DMA zone: 8192 pages used for memmap
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] DMA zone: 0 pages reserved
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] DMA zone: 519168 pages, LIFO batch:31
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] Normal zone: 8136 pages used for memmap
May 24 04:42:31 jetpack-dev-desktop kernel: [ 0.000000] Normal zone: 520704 pages, LIFO batch:31
Here is the syslog file at the the same time:
May 24 04:52:49 jetpack-dev-desktop NetworkManager[4153]: [1590310369.2254] device (wlan0): supplicant interface state: authenticating -> disconnected
May 24 04:52:49 jetpack-dev-desktop nm-applet[6565]: gtk_widget_destroy: assertion ‘GTK_IS_WIDGET (widget)’ failed
May 24 04:52:49 jetpack-dev-desktop nm-applet[6565]: Can’t set a parent on widget which has a parent
^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@May 24 04:42:31 jetpack-dev-desktop systemd-modules-load[1983]: Inserted module ‘bluedroid_pm’
May 24 04:42:31 jetpack-dev-desktop systemd-modules-load[1983]: Module ‘nvhost_vi’ is builtin
May 24 04:42:31 jetpack-dev-desktop systemd-modules-load[1983]: Inserted module ‘nvgpu’
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Starting Flush Journal to Persistent Storage…
May 24 04:42:31 jetpack-dev-desktop systemd-udevd[2657]: Network interface NamePolicy= disabled on kernel command line, ignoring.
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Started Load Kernel Modules.
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Starting Apply Kernel Variables…
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Mounting Kernel Configuration File System…
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Started Set the console keyboard layout.
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Reached target Local File Systems (Pre).
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Reached target Local File Systems.
May 24 04:42:31 jetpack-dev-desktop systemd[1]: Starting Clean up any mess left by 0dns-up…
May 24 04:42:31 jetpack-dev-desktop systemd-sysctl[2691]: Couldn’t write ‘1’ to ‘net/ipv4/tcp_syncookies’, ignoring: No such file or directory
May 24 04:42:31 jetpack-dev-desktop systemd-sysctl[2691]: Couldn’t write ‘1’ to ‘kernel/yama/ptrace_scope’, ignoring: No such file or directory
May 24 04:42:31 jetpack-dev-desktop systemd-sysctl[2691]: Couldn’t write ‘fq_codel’ to ‘net/core/default_qdisc’, ignoring: No such file or directory
Ubuntu 18.04.3
Gnome 3.28.4
