I am very sorry if this is old & known and/or if I failed to search sufficiently in my researching this failure; so bare with me :-).
The card is a GeForce 8800 GT running on a Linux machine with kernel version 2.6.9-42.0.3.ELsmp; it’s a dual AMD Opteron. The issue comes when I am running the nbody SDK program in --compare mode and varying the number of bodies in the system. See the following to get the gist of the failure I’m seeing (power of 2 works, power of 2 + 1 fails):
[ release]$ ./nbody --compare --n=4096
Run “nbody -benchmark [-n=]” to measure perfomance.
Test PASSED
[ release]$ ./nbody --compare --n=4097
Test FAILED
[ release]$ ./nbody --compare --n=8192
Test PASSED
[ release]$ ./nbody --compare --n=8193
Test FAILED
[ release]$
I have just not been able to search & find any posts relating to this failure and am concerned that my setup might be incorrect. Also, if my setup is correct, then am curious if there is error is related to the internal storage format of floats on 8800 versus my Opteron chip.
Again, I apologize if this is known – would love to be enlightened though.
