Hi All
This should be easy to find but I’m struggling…
I have to disable hardware based LLDP so that I can use software LLDP on Rocky Linux 9.4 hosts that have mixed NIC cards in them (using ISC LLDP, all working)
The Connect5X-EX cards have LLDP enabled in hardware so are eating LLDP frames before being passed and not forwarding the software LLDP frames
I have installed the latest Mellanox drivers with tools but can’t seem to find how to do this simple function
Please advise
Cheers
Darren
Thanks for writing us!
To disable hardware-based LLDP on ConnectX-5 EX cards so that you can use software-based LLDP on Rocky Linux 9.4 hosts, you need to use the mlxconfig tool that comes with the Mellanox drivers.
Here are the general steps you would follow to disable hardware-based LLDP using mlxconfig:
- Identify the Device: First, you need to identify the PCI device ID of the ConnectX-5 EX card. You can do this by running the
lspci command and looking for the device in the output.
lspci | grep -i Mel
- Check Current LLDP Configuration: Before making any changes, it’s a good idea to check the current LLDP configuration of the card. You can do this by running the following command:
mlxconfig -d <device_id> query | grep -i LLDP
You should get the settings for LLDP
LLDP_NB_DCBX_P1 True(1)
LLDP_NB_RX_MODE_P1 True(1)
LLDP_NB_TX_MODE_P1 True(1)
LLDP_NB_DCBX_P2 True(1)
LLDP_NB_RX_MODE_P2 True(1)
LLDP_NB_TX_MODE_P2 True(1)
Replace <device_id> with the PCI device ID of your ConnectX-5 EX card.
3. Disable Hardware LLDP: To disable hardware LLDP, you would use the mlxconfig tool with the set parameter to modify the card’s configuration. The exact parameter to disable LLDP might vary based on the firmware version, but it generally looks something like this:
mlxconfig -d <device_id> set <Parameter>=0
Again, replace <device_id> with the PCI device ID of your ConnectX-5 EX card.
4. Apply Changes: After running the above command, you may need reboot the host or reset the network adapter for the changes to take effect.
Hope this helps!
Thanks and have a wonderful day!
Ilan.
Hope this applies to the MT26448.
from “lspci -v” :
07:00.0 Ethernet controller: Mellanox Technologies MT26448 [ConnectX EN 10GigE, PCIe 2.0 5GT/s] (rev b0)
Subsystem: Mellanox Technologies Device 0015
Flags: bus master, fast devsel, latency 0, IRQ 47
Memory at fce00000 (64-bit, non-prefetchable) [size=1M]
Memory at fb800000 (64-bit, prefetchable) [size=8M]
Expansion ROM at fcd00000 [disabled] [size=1M]
Capabilities: [40] Power Management version 3
Capabilities: [48] Vital Product Data
Capabilities: [9c] MSI-X: Enable+ Count=128 Masked-
Capabilities: [60] Express Endpoint, IntMsgNum 0
Capabilities: [100] Alternative Routing-ID Interpretation (ARI)
Capabilities: [148] Device Serial Number 00-02-c9-03-00-54-55-62
Kernel driver in use: mlx4_core
Kernel modules: mlx4_core
root@u25:~/_mft/mft-4.35.0-159-x86_64-deb# mlxconfig -d 07:00.0 query | grep -i LLDP
-E- Failed to open the device
Not sure what to put in for DeviceId.
