I’ve got the jetson TX2 with Jetpack 3.1 and the leopard imaging Triple IMX377 Camera Kit with M12 Lens https://shop.leopardimaging.com/product.sc?productId=321&categoryId=44
We are trying to get very fine accuracy at the pixel level with grayscale images, so we have a need to bypass the ISP and use the raw bayer image. I found that using nvcamerasrc can dump the bayer image to a file, but that’s not a scalable workflow for us. I’ve seen other threads that imply that v4l2src can output the bayer file to memory; however, gstreamer must be patched to use RAW10 rather than RAW8 for this to work. I went about the patching process, but I must have messed up somewhere because now whenever I try to run a gstreamer pipeline using v4l2src, I get an error like the following:
$ gst-launch-1.0 -v v4l2src device=/dev/video0 num-buffers=1 ! “video/x-bayer, format=rggb, width=3280, height=2464” ! filesink location=test_3280x2464.bayer
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason not-negotiated (-4)
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Actually, scratch that. When I put in a width and height that corresponds to the sensor size, the pipeline doesn’t give me an error, but the output is all 0’s:
$ DISPLAY=:0 gst_1.14.0/out/bin/gst-launch-1.0 -v v4l2src device=/dev/video0 num-buffers=1 ! "video/x-bayer, format=rggb, width=4104, height=3046" ! filesink location=test_4104x3046.bayer
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-bayer, format=(string)rggb, width=(int)4104, height=(int)3046, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-bayer, format=(string)rggb, width=(int)4104, height=(int)3046, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/x-bayer, format=(string)rggb, width=(int)4104, height=(int)3046, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-bayer, format=(string)rggb, width=(int)4104, height=(int)3046, framerate=(fraction)30/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
Got EOS from element "pipeline0".
Execution ended after 0:00:03.237484397
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I’m perfectly happy with help solving this whether or not it includes v4l2src. When I capture the image using nvcamerasrc and then use nvvidconv, no matter what settings I use, the resulting image is far too noisy to extract the kind of details we need unless I use the raw bayer file. v4l2src isn’t working as noted. I haven’t yet gone down the path of libargus (mostly because the documentation for compiling and running libargus has been very difficult to come by).
If I could fine tune the shutter, aperture, gain, white balance, edge enhancement, and noise removal that the ISP does and get full-resolution or downsampled image straight from the camera, that’d be ideal. If that can’t happen, then getting the raw bayer image into memory so I can manipulate it myself using opencv would be preferred (and if that takes fixing or reinstalling gstreamer, I’ll need some help with that).
