Hello, I have a jetson orin nano which I flashed with SDK manager and now i dont know, i am not able to use Gstreamer, Cuda, OpenCV properly. please help me with proper steps to flash with a sdk manager from the scratch because i am new to this and just a beginner developer. please give me all the steps. i have not been able to use my Jetson orin nano developer kit at all.
I’d be happy to help you with flashing your Jetson Orin Nano Developer Kit using SDK Manager from scratch.
Prerequisites
Before we begin, make sure you have the following:
- A Linux host machine (e.g., Ubuntu) with internet access.
- A Jetson Orin Nano Developer Kit.
- A USB-C cable to connect the developer kit to the Linux host.
- A display device or a serial console (e.g., minicom) connected to the developer kit.
- A wired Ethernet connection with internet access connected to the developer kit.
- Any required USB peripherals (e.g., keyboard, mouse) connected to the developer kit.
Step 1: Download and Install SDK Manager
- Go to the NVIDIA SDK Manager website and download the SDK Manager for Linux.
- Follow the installation instructions to install SDK Manager on your Linux host machine.
Step 2: Prepare the Jetson Orin Nano Developer Kit
- Connect the Jetson Orin Nano Developer Kit to the Linux host machine using a USB-C cable.
- Connect a display device or a serial console to the developer kit.
- Connect any required USB peripherals (e.g., keyboard, mouse) to the developer kit.
- Connect a wired Ethernet connection with internet access to the developer kit.
Step 3: Launch SDK Manager and Create a New Project
- Launch SDK Manager on your Linux host machine.
- Click on “Create New Project” and select “Jetson Orin Nano Developer Kit” as the target device.
- Choose the desired JetPack version (e.g., JetPack 6.2) and click “Next”.
- Select the desired operating system (e.g., Linux) and click “Next”.
- Choose the desired installation location and click “Next”.
- Review the project settings and click “Create Project”.
Step 4: Flash the Jetson Orin Nano Developer Kit
- In SDK Manager, select the project you created in Step 3.
- Click on “Flash” and select the “Jetson Orin Nano Developer Kit” as the target device.
- Choose the desired flash configuration (e.g., “internal” for flashing to the internal storage).
- Click “Flash” to begin the flashing process.
Step 5: Verify the Flashing Process
- Monitor the flashing process on the SDK Manager console.
- Verify that the flashing process completes successfully.
Step 6: Set up the Jetson Orin Nano Developer Kit
- After flashing, the developer kit will reboot.
- Set up the developer kit by following the on-screen instructions.
- Configure the network settings, user account, and other preferences as desired.
Step 7: Install GStreamer, CUDA, and OpenCV
- Once the developer kit is set up, you can install GStreamer, CUDA, and OpenCV using the following commands:
sudo apt-get update
sudo apt-get install gstreamer1.0
sudo apt-get install cuda-toolkit-11-6
sudo apt-get install libopencv-dev
Comparison with Other Methods
Flashing the Jetson Orin Nano Developer Kit using SDK Manager is a more comprehensive and user-friendly approach compared to other methods. SDK Manager provides a graphical interface for flashing and setting up the developer kit, making it easier for beginners to get started.
In contrast, flashing using the flash.sh script requires more manual steps and command-line interactions. While this method is still viable, SDK Manager provides a more streamlined and user-friendly experience.
I hope this helps you get started with flashing your Jetson Orin Nano Developer Kit using SDK Manager!
