How to install sdk developer kit on jetson agx orin arm64 architecture
how to install sdk developer kit on jetson agx orin arm64 architecture , and please provide me how to install cuda and pytorch
You mean how to install JetPack on your AGX Orin?
Please follow the guide:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
Hi , please find the screen shot, i am not able to select anything, please guide me properly.
Did you put the device in force recovery mode?
Or you don’t know what I’m talking about?
i font know to put device on force recovery mode
Google gives you:
ok after doing force recovery wjat i have to do???
Then you are able to select it in the SDK Manager, and follow the guide.
do i need jumper wire also for force start or i can just use usb cable and press force start and reset button together
I think it’s stated very clearly in the link I posted.
You only need to play with buttons, but not jumpers or wires.
Unplug the power supply. Connect the usb cable. Press and hold the middle button, keep it pressed while plugging in the power cable. Now proceed to open the sdk manager. Use ubuntu 20.04 (jetpack 5) but if not ubuntu 22.04 you must wait for JetPack 6.
hi brother,
actually i new to this and bought this device for my study purpose that why i m scared.
i have one question sdk manager will automatically get open or i have to install it first???
You have to manually install and launch it…
but whem i m installing it , i m getting amd64 version , but i am using arm64 jeston agx orin.so please guide and help me.
You need a x86 PC for flashing Jetson devices.
SDK Manager has to be installed on the x86 Ubuntu PC, but not Jetson.
please find tge screen shot , from the screen shot i have to select .deb ubuntu then i will sdkmanager version amd64 that i have to open manually???when flashing
I don’t know what you are talking about.
You need an x86 PC for flashing Jetson devices, and SDK Manager has to be installed on an x86 host PC. You cannot use a Jetson device to flash another Jetson device.
You’d better do some study before asking some very very basic questions.
your documentation is not clear about jetson agx orin , you have just mentioned about jetson xavier and nano.
that why i asked you
