need some help setting up cuda
How can i set up CUDA, to use in device emulation mode on a windows based box with no CUDA capable device.
I tried installing CUDA toolkit but it came out saying that no CUDA driver, which i can;t install since i have no CUDA capable device.
I needed this setup CUDA to (atleast debug) on my notebook, any help/suggestions for is greatly appreciated.
thanks in advance.
peace
You need these main steps to run CUDA using emulation mode on windows:
  1. Install CUDA toolkit
  2. Install CUDA SDK
  3. Install Visual Studio 2005 Express or Full edition( I didn’t try Visual Studio 2008 )
  4. Add cuda/bin in the path env variable
  5. make sure you have these environment variables based on your installation directories
CUDA_BIN_PATH: i.e. C:\CUDA\bin
CUDA_COMMON_INC_PATH: i.e. C:\Program Files\NVIDIA Corporation\NVIDIA CUDA SDK\common\inc
CUDA_COMMON_LIB_PATH: i.e. C:\Program Files\NVIDIA Corporation\NVIDIA CUDA SDK\common\lib
CUDA_INC_PATH: i.e. C:\CUDA\include
CUDA_LIB_PATH: i.e. C:\CUDA\lib
NVSDKCUDA_ROOT: i.e. C:\Program Files\NVIDIA Corporation\NVIDIA CUDA SDK
  1. Install CUDA_VS2005 plugin to Integrate CUDA with Visual C++
http://forums.nvidia.com/index.php?showtopic=65111
http://sarathc.wordpress.com/2008/09/26/ho…-with-visual-c/
  1. Enable Syntax Highlighting for CUDA in Visual Studio
http://sarathc.wordpress.com/2008/09/04/ho…al-studio-2005/
The other thing, when you try to run your code make sure you are using Emudebug if you do the integration using CUDA_VS2005 plugin.
I hope that helps!
–OA
thanks a lot OA…that did the trick…
it helped a lot… External Media
I downloaded and installed everything, but the folder (NVIDIA CUDA SDK) does not and instead I get this folder, I get “NVIDIA GPU Computing SDK Browser”
Who can help me further or give a link where everything is explained step by step???
I need it urgently …
Merci :)
I am a beginner, but my guess is that the folder name changes with the CUDA SDK version you install. That should not have any problems.
