NemoClaw sandbox: missing PVC (volumeClaimTemplates: []) causes total data loss on container OOM/restart — contradicts docs
Running NemoClaw v0.1.0 (cluster image Package openshell/cluster · GitHub , sandbox image
openshell/sandbox-from:1775835188) on macOS + Docker Desktop (Apple Silicon, arm64). Two bugs hit within a single
day of moderate use. Details and evidence below.
BUG 1 — No PVC provisioned; all data lost on container restart
The Workspace Files docs ( Workspace Files — NVIDIA NemoClaw Developer Guide ) explicitly
state:
"The sandbox uses a Persistent Volume Claim (PVC) that outlives individual container restarts."
But on my install, the Sandbox CRD was created without any PVC:
  $ kubectl get sandbox aimee-assistan2 -n openshell -o json | jq '.spec.volumeClaimTemplates'
  $ kubectl get sandbox aimee-assistan2 -n openshell -o yaml | grep -A 6 "^      volumes:"
  volumes:
  - name: openshell-client-tls
    secret: {secretName: openshell-client-tls}
  - hostPath: {path: /opt/openshell/bin, type: DirectoryOrCreate}
No PVC, no emptyDir, no hostPath for /sandbox/ or /sandbox/.openclaw-data/. Everything at those paths (skills,
workspace .md files, agents/, device pairing) lived in the container’s writable overlay layer.
When the kubelet restarted the agent container, every persistent path was reset to the image defaults. Lost:
  • /sandbox/.openclaw/workspace/SOUL.md, USER.md, IDENTITY.md, AGENTS.md, memory/
  • /sandbox/.openclaw-data/skills/google-analyzer/ (148MB custom skill)
  • Device pairing state (had to re-pair TUI and dashboard)
Note: /sandbox/.openclaw/skills is a symlink → /sandbox/.openclaw-data/skills, so without a PVC on .openclaw-data,
skills are inherently ephemeral even if workspace/ were somehow protected.
BUG 2 — No default memory limit on the agent container
  $ kubectl get pod aimee-assistan2 -o yaml | grep -A 1 "resources:"
  resources: {}
With no memory limit, a batch running CPU-based faster-whisper transcription (analyzing Google Drive videos via a
skill) grew unbounded until the kernel OOM-killer terminated the container:
  lastState:
    terminated:
      exitCode: 137
      reason: OOMKilled
      startedAt: "2026-04-23T05:46:46Z"
      finishedAt: "2026-04-23T20:16:01Z"
Because no per-pod limit is set, memory pressure affected the whole Docker Desktop VM, not just this pod — other
pods could have been evicted as collateral damage.
Related existing issues I also encountered
restart (nemoclaw-start.sh only runs at sandbox creation, not on pod recreation). Hit this ~5 times today.
My OPENSHELL_SSH_HANDSHAKE_SECRET env var in the Sandbox CRD had a stale value after a helm chart upgrade rotated
the server-side value; I had to manually patch the CRD to match before the TUI could connect.
Workaround I hand-applied
1. Created a 10Gi PVC with local-path StorageClass:
 kubectl apply -f - <<EOF
 apiVersion: v1
 kind: PersistentVolumeClaim
 metadata:
   namespace: openshell
 spec:
   resources: {requests: {storage: 10Gi}}
   storageClassName: local-path
 EOF
2. Patched the Sandbox CRD to add the volume + mount:
 kubectl patch sandbox aimee-assistan2 -n openshell --type=json -p='\[
   {"op":"add","path":"/spec/podTemplate/spec/volumes/-","value":{"name":"openclaw-data","persistentVolumeClaim"
:{“claimName”:“aimee-assistan2-openclaw-data”}}},
   {"op":"add","path":"/spec/podTemplate/spec/containers/0/volumeMounts/-","value":{"mountPath":"/sandbox/.openc
law-data",“name”:“openclaw-data”}}
3. Added resource requests/limits (prevent whole-node memory pressure):
 {"requests":{"memory":"512Mi","cpu":"250m"},"limits":{"memory":"4Gi"}}
4. Force pod recreation + restore data from local backup (~/.nemoclaw/backups/).
Data now survives container restarts, OOMs are container-scoped.
Questions for the NemoClaw team
1. Is the missing PVC a setup-flow bug, or is my install corrupted? Should a fresh `nemoclaw onboard` always
produce a Sandbox CRD with a PVC?
2. Are there plans to ship default `resources.requests`/`resources.limits` in the generated Sandbox podTemplate?
Running without any memory cap is a footgun on Docker-Desktop-hosted clusters.
3. Is there a supported path to migrate an existing sandbox from ephemeral-overlay to PVC-backed storage without
losing data? `nemoclaw rebuild` is mentioned in docs — does it add a PVC if one is missing?
4. Should `/sandbox/.openclaw/skills` be a symlink at all? It makes skill persistence depend on persistence of
`.openclaw-data/`, which has different guarantees from `workspace/`.
Happy to run additional diagnostics or provide a `nemoclaw debug` tarball if useful.
Hi @Smithaimee — great bug report, and your workaround is basically what I would have done. A few additions and one caution.
**On the missing PVC:** this looks like a setup-flow bug, not corruption. The docs say a PVC should be provisioned, and an empty `volumeClaimTemplates` array contradicts that. If you installed via `nemoclaw onboard`, the onboarding template may have failed to render the PVC for Docker Desktop’s `local-path` StorageClass. On a real cluster with a default StorageClass, the same template probably works. Worth checking:
```bash
kubectl get storageclass
kubectl get sc local-path -o yaml
If no default SC exists, the PVC creation would silently fail, which could explain the empty array.
**Your workaround is solid, with one tweak.** Mounting to `/sandbox/.openclaw-data` preserves skills and data, but you may also want to mount a separate PVC or hostPath for `/sandbox/.openclaw/workspace` if the docs treat workspace files as independently persistent. From your report, it sounds like workspace/ is also in the overlay, so your current PVC already covers it only if the symlink chain resolves under `.openclaw-data`. I’d verify with:
```bash
kubectl exec -it aimee-assistan2-0 -n openshell – readlink -f /sandbox/.openclaw/workspace
**On default resource limits:** agreed, running without requests/limits is a footgun. For Docker Desktop, I’d suggest even tighter limits than 4 GiB unless you know faster-whisper needs more. Something like:
```yaml
resources:
requests: {memory: “512Mi”, cpu: “250m”}
limits: {memory: “2Gi”, cpu: “2000m”}
Then add a separate `faster-whisper` job pod with a higher limit when needed, rather than letting the agent container burst.
**On migration:** the safest path to migrate an existing sandbox to PVC-backed storage is exactly what you did — create the PVC, patch the CRD, then force a rolling recreation. `nemoclaw rebuild` might recreate the sandbox spec from the original template, which could wipe your patch. Test rebuild on a throwaway sandbox first.
Hope the NemoClaw team picks this up — the PVC + resource defaults should really be part of the standard onboarding manifest.
