Is it possible to do network booting(PXE or other) on one device to Jetpack 5.1.2 and Jetpack 6.1 images?
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/FlashingSupport.html#configuring-a-pxe-boot-server-for-uefi-bootloader-on-jetson
According to beforementioned guidance, no devicetree option is given in grub.cfg file and according to boot and flashing log I suppose it is read from EFI partition. After flashing Jetpack 6.1 image to Jetson AGX orin, I did PXE boot succefully with Jetpack 6.1 image/initrd and NFS rootfs. I tried to use Jetpack 5.1.2 image/initrd and nfs rootfs, but it leads to kernel panic during boot-up.
Is it possible to do PXE boot to Jetpack 5.1.2 (or any other Jetpack 5.*) and Jetpack 6.1 on one single Jetson AGX Orin without flashing device between booting?
serial log in attachment from trying out to PXE boot Jetpack 5.1.2 after flashed Jetpack 6.1 image to device:
kernel_panic_512_on_flashed_61.log (199.9 KB)
I didn’t find help from given links. I suppose I either understood you incorrectly or my questions are not clear. I don’t feel need for another ticket, but would just like to get help related to image PXE booting for Jetson AGX Orin. So I can descripe steps to reproduce this.
- Flash Jetpack 5.1.2 to Jetson AGX Orin(exact model 945-13730-0000-000) using NVIDIA SDK manager
- Flash Jetpack 6.1 to same device using NVIDIA SDK manager
- Configure tftp, dhcp and grub to make booting to Jetpack 6.1 according guide: Flashing Support — NVIDIA Jetson Linux Developer Guide 1 documentation) 4) Configure tftp, dhcp and grub to make booting to Jetpack 5.1.2 according guide: Flashing Support — NVIDIA Jetson Linux Developer Guide 1 documentation
OBSERVED RESULTS:
In step 4) device reach kernel panic during boot-up
HOPED/EXPECTED RESULTS:
Device can be PXE booted for both Jetpack 5.1.2 and Jetpack 6.1 images
There is no support as UEFI does not support jetpack6.1 and jp5 at same time
