Network Streaming issue in Argus camera - Jetpack 5.1.2
Hi Nvidia,
I am using Jetson Orin nano with Jetpack 5.1.2 with ov2311 camera module. I am able to view stream in argus_camera application. When i try to do network streaming in this setup through remote ssh terminal, i am not able to do so.
Even, if i run fakesink, i am getting the same error as mentioned below.
hi:~$ gst-launch-1.0 nvarguscamerasrc ! fakesink
libEGL warning: DRI3: failed to query the version
libEGL warning: DRI2: failed to authenticate
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 89)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:320 Failed to create FrameConsumer
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:241 (propagating)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, waitRunning:203 Invalid thread state 3
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:806 (propagating)
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.138794841
Setting pipeline to NULL …
Freeing pipeline …
I would appreciate any solution for this as we cannot use display monitor in our usecase. We need to use remote ssh terminal for streaming purpose.
Thanks in advance.
Please set up UDP/RTSP as suggested in
Is it possible to run a GStreamer pipeline in headless mode with the source plugin nvarguscamerasrc?
Thanks for the reply. I will check and update you.
Thanks team. Just using ssh without -X worked for me. Thanks for the information.
