e-con Systems introduces DepthVista Helix, the next-generation 1.2MP 3D CW iToF camera featuring the onsemi AF0130 sensor for accurate and reliable 3D depth sensing in robotics & smart automation systems. Building on the trusted DepthVista legacy, it delivers enhanced depth performance, long-range measurement, and easy integration across multiple compute platforms, including NVIDIA® Jetson Orin™. Click to Download Datasheet »
Target Applications
- Warehouse Automation
- Pick and Place Robots
- Palletization & Depalletization Robots
- Autonomous Mobile Robots (AMRs)
- Industrial Safety and Automation
- Smart Agriculture
- Row detection
- Harvesting
Why DepthVista Helix for you?
On-Camera Depth Processing with ultra-high Accuracy: Processes depth within the camera itself, reducing compute load on the host system while performing high-precision measurements with reduced multipath effects.
High-Resolution 1.2MP Depth @ 60 fps: Leverages onsemi Hyperlux ID AF0130 sensor to detect smaller obstacles, pallet edges, and object height variations with dense depth data and enhanced spatial detail for more accurate robotic perception.
Flexible Interface Support: Available with GMSL, USB, or MIPI interfaces for easy integration across robotics and automation systems.
Comprehensive SDK Support: Provides Linux drivers, sample applications, and depth visualization tools through e-con’s DepthVista SDK for faster integration and deployment.
Industrial grade design: IP67-rated to withstand harsh industrial environments, dust, and water—built for reliable 24/7 deployment in warehouses, and outdoor robotics applications.
Extensive customization + integration support
e-con Systems, with deep embedded vision expertise, provides the necessary customization services and end-to-end integration support for DepthVista Helix – meeting all your application’s unique requirements.
