e-con Systems’ Darsi™ Pro is an edge AI compute box powered by the NVIDIA® Jetson Orin™ NX, engineered for mobility and AI vision applications. This production-ready compute platform delivers advanced edge AI processing, seamless multi-sensor integration, a wide operating temperature range, and industrial-grade reliability - making it ideal for real-time perception in dynamic environments.
Darsi™ Pro supports diverse sensors, secure cloud-based device management platform and leading AI frameworks, enabling faster development and deployment across Autonomous Mobile Robots (AMRs), Delivery Robots, Warehouse Forklifts, and Intelligent Transportation Systems.
Why Choose e-con’s Compute Box?
Extensive camera compatibility
Easily integrate e-con Systems’ wide portfolio of cameras, allowing users to choose the right imaging solution tailored to their application requirements. -
Multi-sensor fusion
Synchronize inputs from RADAR, LiDAR, cameras, IMUs, and other sensors using PTP, enabling real-time decision-making in robotics, mobility, and autonomous systems. -
Cloud Management and OTA-Enabled
Flexible connectivity
Equipped with dual GbE with PoE, USB3.2, HDMI, wireless modules (Wi-Fi/LTE/GNSS/e-SIM), it supports versatile deployment scenarios. -
Industrial-grade design
With an IP67-rated enclosure, wide temperature tolerance, this solution is ready for field deployment in harsh industrial and outdoor environments. -
High-performance edge AI compute
Harness NVIDIA Ampere GPU architecture with up to 1024 CUDA cores and 100 TOPS AI performance, optimized for advanced vision workloads. -
MCU-based smart power management
MCU handles overall system power management, including startup and shutdown sequencing for Jetson and peripherals, support for low-power operational modes, and event handling for sleep, wake-up, and soft reboots—ensuring reliable and efficient operation in the field.
Supported Cameras
- STURDeCAM31 - 3MP Sony ISX031 120dB HDR Camera
- STURDeCAM88 - 4K 140dB HDR Front View Camera
- STURDeCAM57 - 5MP RGB-IR Global shutter Camera
