No 144Hz option for Asus MG279Q Monitor
I’m using the MG278 with a Geforce 660 Ti and 361.42. I should be able to choose 1080p144 from the settings, but the maximum I get is 60Hz. For some reason I can choose 100Hz when using 1440p.
On Windows I can create custom resolutions easily, why can’t I do that here?
Following up on the problem.
Running 375.10 now and I still have the same issue (no 144Hz option). One thing that this driver did fix for me. Before, the monitor would show any image while in “text mode” (from BIOS until X starts). If I changed back to a tty, the monitor would show as “No signal” and then gonne into standby. Now, I do have tty working after the first X start (I never saw this on this monitor/card). Only noticed the change on this latest driver (375.xx).
Is the issue forgotten or anyone at nvidia still wants to check it out?
