No devices were found after upgrade NVIDIA driver from 460.86 to 510.60.02 on Ubuntu 20.04 for RTX 3080
I have a machine which works well with NVIDIA 460.86 driver.
Recently I need run something with CUDA 11.5, so I decide to upgrade the NVIDIA driver to 510.60.02 via ubuntu-drivers. But for many times tries it still not work: “No devices were found” is what I get by nvidia-smi.
From dmesg I found some message, it seems something wrong with snd_hda_intel:
[    2.728502] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    2.738022] snd_hda_intel 0000:01:00.1: Disabling MSI
[    2.738028] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    2.738163] snd_hda_intel 0000:06:00.1: Disabling MSI
[    2.738167] snd_hda_intel 0000:06:00.1: Handle vga_switcheroo audio client
[    2.742174] snd_hda_intel 0000:00:1f.3: no codecs found!
[    2.769305] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[    2.769364] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[    2.769414] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[    2.769464] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[    2.769511] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[    2.769556] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[    2.769603] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[    2.771480] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:06:00.1/sound/card2/input20
[    2.771634] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:06:00.1/sound/card2/input21
[    2.771774] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:06:00.1/sound/card2/input22
[    2.771870] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:06:00.1/sound/card2/input23
[    2.771933] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.1/0000:06:00.1/sound/card2/input24
[    2.772066] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.1/0000:06:00.1/sound/card2/input25
[    2.772221] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.1/0000:06:00.1/sound/card2/input26
[    2.779522] nvidia 0000:06:00.0: enabling device (0000 -> 0003)
[    2.779630] nvidia 0000:06:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[    2.822503] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  510.60.02  Wed Mar 16 11:24:05 UTC 2022
[    2.847713] usb 1-10: reset high-speed USB device number 4 using xhci_hcd
[    2.849613] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  510.60.02  Wed Mar 16 11:17:28 UTC 2022
[    2.851203] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    2.871504] loop9: detected capacity change from 0 to 126760
[    2.872835] intel_tcc_cooling: Programmable TCC Offset detected
[    2.876060] intel_rapl_common: Found RAPL domain package
[    2.876061] intel_rapl_common: Found RAPL domain core
[    2.876063] intel_rapl_common: Found RAPL domain dram
[    2.876065] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[    2.876069] intel_rapl_common: RAPL package-0 domain dram locked by BIOS
[    2.998090] mt7601u 1-10:1.0: ASIC revision: 76010001 MAC revision: 76010500
[    3.029930] mt7601u 1-10:1.0: EEPROM ver:0d fae:00
[    3.243942] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    3.244144] usbcore: registered new interface driver mt7601u
[    3.245823] mt7601u 1-10:1.0 wlx1cbfce8b566c: renamed from wlan0
[    3.599635] loop10: detected capacity change from 0 to 509456
[    4.051841] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1463)
[    4.051970] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[    4.052327] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
[    4.052509] [drm:nv_drm_probe_devices [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register device
[    4.052608] [drm] [nvidia-drm] [GPU ID 0x00000600] Loading driver
[    4.319615] loop11: detected capacity change from 0 to 133552
[    5.191284] NVRM: GPU 0000:06:00.0: RmInitAdapter failed! (0x26:0x56:1463)
[    5.191311] NVRM: GPU 0000:06:00.0: rm_init_adapter failed, device minor number 1
[    5.191381] [drm:nv_drm_load [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000600] Failed to allocate NvKmsKapiDevice
[    5.191526] [drm:nv_drm_probe_devices [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000600] Failed to register device
[    5.194701] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[    5.196445] nvidia-uvm: Loaded the UVM driver, major device number 506.
Please help.
Thanks very much.
nvidia-bug-report.log.gz (249.4 KB)
Known driver bug, you’ll have to stay on 460 until fixed unfortunately.
Thank you.
I saw another reply by you in another thread. It said
The real problem is your 12th gen intel igpu, the 20.04 kernel is too old to support it.
Unfortunately, in order to fix it, you tried to install all kinds of nvidia drivers over another, so I don’t know which state that has. Please remove the/any nvidia driver using the Software&Updates application, run the runfile installer with --uninstall option to get a clean system, then upgrade the kernel using the liquorix ppa"
Was that reply related with this problem, and I can upgrade the kernel to make it work?
That’s unrelated to your issue. You have an nvidia-only system, the driver bug is unrelated to the kernel version. You could check for a bios update, though.
Roger that. Thank you.
