• Hardware Platform (Jetson / GPU) Tesla V100-PCIE
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) -
• TensorRT Version 8.4.1.5
• NVIDIA GPU Driver Version (valid for GPU only) 470.129.06
• Issue Type( questions, new requirements, bugs) No EOS signal in the second video in runtime add or delete source
• How to reproduce the issue? I have made the changes according to my requirement and attached the “deepstream_rt_src_add_del_exp.py”. To produce the issue run it in deepstream-6.1/sources/deepstream_python_apps/apps/runtime_source_add_delete
• Requirement details -
I have to process the videos one by one without loading the models again and again. Once a video gets a EOS the next video should start processing and it should continue like this.
For that I did some changes in the original deepstream_rt_src_add_del.py, as originally it was adding source after 10 sec.
After the processing of the first video when EOS message comes then my pipeline added the second source, but once the second finishes it does not give EOS and due to that the pipeline cannot add the new source,
deepstream_rt_src_add_del_exp.py (24.3 KB)
