No GPU option in Digits. Closed
Similar to issue https://github.com/NVIDIA/DIGITS/issues/1085
Building CUDA and cuNN without errors. Configured caffe makfiles for GPU, also without errors.
I built digits 6 as per https://github.com/NVIDIA/DIGITS/blob/master/docs/BuildDigits.md
As in the issue above, I don’t have an option at the digits web frontend to use GPU to train a new model.
But, when I run
digits/device_query.py
The GPU is properly detected:
`Device #0:
CUDA attributes:
name GeForce GTX 960M
totalGlobalMem 2100232192
clockRate 1176000
major 5
minor 0
NVML attributes:
Total memory 2002 MB
Used memory 1788 MB
Memory utilization 3%
GPU utilization 9%
Temperature 62 C
I debuged digits/model/tasks/caffe_train.py and displayed
config_value('caffe')['cuda_enabled'] = true
config_value('gpu_list') = 0
My apologies. This is a non issue. It’s true that I didn’t get an option to select a GPU like in the tutorial I was following, but in the end, it was using the GPU properly.
I just requested that the Model be trained, and the next screen showed all statistics including the Nvidia GPU.
