Hi there,
Im actually working with a ASUS ROG Zephyrus Duo 15 SE GX551QS
After installing several Linux Distros (Ubuntu & Pop!OS) the RTX 3080 is gone. The GPU is not detected neither in BIOS.
Bug-Report:
nvidia-bug-report.log (1.2 MB)
I already searched many forums.
Could you please help ?
Scanning kernel log files for NVIDIA kernel messages:
/var/log/kern.log:
Jun 13 17:16:59 OMsys kernel: [ 737.008705] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:16:59 OMsys kernel: [ 737.008709] NVRM: No NVIDIA GPU found.
Jun 13 17:16:59 OMsys kernel: [ 737.009136] nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:00 OMsys kernel: [ 737.318252] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:17:00 OMsys kernel: [ 737.318256] NVRM: No NVIDIA GPU found.
Jun 13 17:17:00 OMsys kernel: [ 737.318645] nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:00 OMsys kernel: [ 737.664336] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:17:00 OMsys kernel: [ 737.664341] NVRM: No NVIDIA GPU found.
Jun 13 17:17:00 OMsys kernel: [ 737.664723] nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:00 OMsys kernel: [ 738.010824] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:17:00 OMsys kernel: [ 738.010829] NVRM: No NVIDIA GPU found.
Jun 13 17:17:00 OMsys kernel: [ 738.011224] nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:01 OMsys kernel: [ 738.342036] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:17:01 OMsys kernel: [ 738.342041] NVRM: No NVIDIA GPU found.
Jun 13 17:17:01 OMsys kernel: [ 738.342466] nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:01 OMsys kernel: [ 738.678145] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:17:01 OMsys kernel: [ 738.678151] NVRM: No NVIDIA GPU found.
Jun 13 17:17:01 OMsys kernel: [ 738.678596] nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
and
/var/log/dmesg:
journalctl -b -0:
Jun 13 17:04:51 OMsys nvidia-settings-autostart.desktop[1747]: ERROR: NVIDIA driver is not loaded
Jun 13 17:05:49 OMsys nvidia-settings.desktop[3274]: ERROR: NVIDIA driver is not loaded
Jun 13 17:05:49 OMsys nvidia-settings[3274]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Jun 13 17:05:49 OMsys nvidia-settings[3274]: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
Jun 13 17:05:49 OMsys nvidia-settings.desktop[3274]: ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
Jun 13 17:05:49 OMsys nvidia-settings[3274]: PRIME: No offloading required. Abort
Jun 13 17:05:49 OMsys nvidia-settings[3274]: PRIME: is it supported? no
Jun 13 17:12:54 OMsys sudo[7659]: omo : TTY=pts/0 ; PWD=/home/omo ; USER=root ; COMMAND=/usr/bin/apt install nvidia-driver-470
Jun 13 17:13:20 OMsys userdel[7722]: delete user 'nvidia-persistenced'
Jun 13 17:13:20 OMsys userdel[7722]: removed group 'nvidia-persistenced' owned by 'nvidia-persistenced'
Jun 13 17:13:20 OMsys userdel[7722]: removed shadow group 'nvidia-persistenced' owned by 'nvidia-persistenced'
Jun 13 17:13:27 OMsys groupadd[8689]: group added to /etc/group: name=nvidia-persistenced, GID=137
Jun 13 17:13:27 OMsys groupadd[8689]: group added to /etc/gshadow: name=nvidia-persistenced
Jun 13 17:13:27 OMsys groupadd[8689]: new group: name=nvidia-persistenced, GID=137
Jun 13 17:13:27 OMsys useradd[8695]: new user: name=nvidia-persistenced, UID=129, GID=137, home=/nonexistent, shell=/usr/sbin/nologin, from=/dev/pts/2
Jun 13 17:13:27 OMsys usermod[8702]: change user 'nvidia-persistenced' password
Jun 13 17:13:27 OMsys chage[8709]: changed password expiry for nvidia-persistenced
Jun 13 17:13:27 OMsys chfn[8713]: changed user 'nvidia-persistenced' information
Jun 13 17:16:53 OMsys sudo[24725]: omo : TTY=pts/0 ; PWD=/home/omo ; USER=root ; COMMAND=/usr/bin/nvidia-bug-report.sh
Jun 13 17:16:59 OMsys kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:16:59 OMsys kernel: NVRM: No NVIDIA GPU found.
Jun 13 17:16:59 OMsys kernel: nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:00 OMsys kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:17:00 OMsys kernel: NVRM: No NVIDIA GPU found.
Jun 13 17:17:00 OMsys kernel: nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:01 OMsys kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Jun 13 17:17:01 OMsys kernel: NVRM: No NVIDIA GPU found.
Jun 13 17:17:01 OMsys kernel: nvidia-nvlink: Unregistered the Nvlink Core, major device number 509
Jun 13 17:17:32 OMsys sudo[25459]: omo : TTY=pts/1 ; PWD=/home/omo/Dokumente ; USER=root ; COMMAND=/usr/bin/nvidia-bug-report.sh
and
journalctl -b -1:
Jun 13 17:00:03 OMsys nvidia-settings-autostart.desktop[1620]: ERROR: NVIDIA driver is not loaded
Jun 13 17:00:58 OMsys sudo[4015]: omo : TTY=pts/0 ; PWD=/home/omo ; USER=root ; COMMAND=/usr/bin/apt-get install nvidia-prime
Jun 13 17:01:26 OMsys userdel[4140]: delete user 'nvidia-persistenced'
Jun 13 17:01:26 OMsys userdel[4140]: removed group 'nvidia-persistenced' owned by 'nvidia-persistenced'
Jun 13 17:01:26 OMsys userdel[4140]: removed shadow group 'nvidia-persistenced' owned by 'nvidia-persistenced'
Jun 13 17:01:58 OMsys nvidia-settings.desktop[4431]: ERROR: NVIDIA driver is not loaded
Jun 13 17:01:58 OMsys nvidia-settings[4431]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Jun 13 17:01:58 OMsys nvidia-settings[4431]: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
Jun 13 17:01:58 OMsys nvidia-settings.desktop[4431]: ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
Jun 13 17:01:58 OMsys nvidia-settings[4431]: PRIME: No offloading required. Abort
Jun 13 17:01:58 OMsys nvidia-settings[4431]: PRIME: is it supported? no
Jun 13 17:04:06 OMsys groupadd[15336]: group added to /etc/group: name=nvidia-persistenced, GID=137
Jun 13 17:04:06 OMsys groupadd[15336]: group added to /etc/gshadow: name=nvidia-persistenced
Jun 13 17:04:06 OMsys groupadd[15336]: new group: name=nvidia-persistenced, GID=137
Jun 13 17:04:06 OMsys useradd[15342]: new user: name=nvidia-persistenced, UID=129, GID=137, home=/nonexistent, shell=/usr/sbin/nologin, from=/dev/pts/2
Jun 13 17:04:06 OMsys usermod[15349]: change user 'nvidia-persistenced' password
Jun 13 17:04:06 OMsys chage[15356]: changed password expiry for nvidia-persistenced
Jun 13 17:04:06 OMsys chfn[15360]: changed user 'nvidia-persistenced' information
and
journalctl -b -2:
Jun 13 16:47:43 OMsys PackageKit[1413]: in /13_adbbeddd for install-packages package nvidia-settings;510.47.03-0ubuntu1;amd64;+manual:ubuntu-jammy-main was installing for uid 1000
Jun 13 16:47:50 OMsys nvidia-settings[5870]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Jun 13 16:47:50 OMsys nvidia-settings[5870]: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
Jun 13 16:47:50 OMsys nvidia-settings.desktop[5870]: ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
Jun 13 16:47:50 OMsys nvidia-settings[5870]: PRIME: Kindprozess »/usr/bin/prime-supported« konnte nicht ausgeführt werden (Datei oder Verzeichnis nicht gefunden)
Jun 13 16:47:50 OMsys nvidia-settings[5870]: PRIME: is it supported? no
Jun 13 16:57:10 OMsys groupadd[10016]: group added to /etc/group: name=nvidia-persistenced, GID=137
Jun 13 16:57:10 OMsys groupadd[10016]: group added to /etc/gshadow: name=nvidia-persistenced
Jun 13 16:57:10 OMsys groupadd[10016]: new group: name=nvidia-persistenced, GID=137
Jun 13 16:57:10 OMsys useradd[10022]: new user: name=nvidia-persistenced, UID=129, GID=137, home=/nonexistent, shell=/usr/sbin/nologin, from=/dev/pts/2
Jun 13 16:57:11 OMsys usermod[10029]: change user 'nvidia-persistenced' password
Jun 13 16:57:11 OMsys chage[10036]: changed password expiry for nvidia-persistenced
Jun 13 16:57:11 OMsys chfn[10040]: changed user 'nvidia-persistenced' information
Jun 13 16:58:02 OMsys nvidia-settings.desktop[25831]: ERROR: NVIDIA driver is not loaded
Jun 13 16:58:02 OMsys nvidia-settings[25831]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Jun 13 16:58:02 OMsys nvidia-settings[25831]: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
Jun 13 16:58:02 OMsys nvidia-settings.desktop[25831]: ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This file should have been installed along with this driver at /usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be listed in the help text. Please see the README for possible values and descriptions.
Jun 13 16:58:02 OMsys nvidia-settings[25831]: PRIME: No offloading required. Abort
Jun 13 16:58:02 OMsys nvidia-settings[25831]: PRIME: is it supported? no
Edit 2:
Result of some commands from this Thread:
gpu-not-detected-ubuntu/108341/2
lspci | egrep -i "vga|display|3d"
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4)
grep 10de /lib/udev/rules.d/*
/lib/udev/rules.d/71-nvidia.rules:SUBSYSTEM=="pci", ATTRS{vendor}=="0x10de", DRIVERS=="nvidia", TAG+="seat", TAG+="master-of-seat"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x03[0-9]*", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", TEST=="power/control", ATTR{power/control}="auto"
lspci -v | grep VGA
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4) (prog-if 00 [VGA controller])
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
and
there is no file 50-pm-nvidia.rules in /lib/udev/rules.d/
Edit 3:
The BIOS Version is 405 (most recent) ASUS ROG. There is no option to disable or enable GPU in this BIOS.
Please help
Edit 4:
If you turn on iGPU in Windows, the NVIDIA GPU will turn off and will not be available in linux, cannot detect with “lspci”. I will now try to install windows again and activate the GPU.
