I have no materials (or environments) after I updated Create to 2022.1.3. Same if I open an older version of Create. What has happened?
Can you check the status of your Cache and internet connection?
Normally this happens if something is blocking you from the amazon S3 server.
Check that cache is running by going here: http://localhost:3080/
If it is and you’re still having an issue, please hit “STOP” on cache and restart cache and create. Let me know if this clears the issue.
That solved the issue. Thanks a lot @DaneTrain !
I had the same issue this seems indeed to work but I still have Create crashing when I select Materials > Library, is this normal ?
thanks
