I am trying to use NVTX to profile some functions. Here are the code changes :
# include <nvtx3/nvtx3.hpp>
nvtxRangePushA(“my_function”);
printProperties(&properties); // Function call
nvtxRangePop();
I am able to create a binary for x86 system (Used this DriveWorks SDK Reference: Getting Started Using the NVIDIA DRIVE OS NGC Docker Container)
Now I am using this binary on a linux x86 machine to be profiled on nsys. Used both nsys-ui (v2023.2.1) and CLI. On nys CLI I used this : sudo nsys profile -t nvtx --stats=true -b dwarf --force-overwrite true -o “result-file” “x86-binary”. I get the message : “No NVTX events collected. Does the process use NVTX” Any ideas how to debug this? Thanks
Hi.
Please try and build the binary for x64, also you are missing “=” after the “–force-overwrite”.
It should be “–force-overwrite=true”.
Please update me on any progress
Good Luck!
By default only messages, provided by NVTX registered strings are considered to avoid additional overhead.
We strongly recommend using registered strings. To enable non-registered strings check please launch your application with NSYS_NVTX_PROFILER_REGISTER_ONLY=0 environment:
