I am getting this error when I trying to run GStreamer command. Please help me if anyone have experienced with this error.
gst-launch-1.0 -e -v
rtspsrc protocols=tcp location=rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mp4 ! rtph264depay ! h264parse ! nvv4l2decoder ! tee name=t \
t. ! queue ! nvv4l2h264enc ! h264parse ! hlssink2 location=“/mnt/hls/%06d.ts”
t. ! queue ! nvv4l2h264enc ! mpegtsmux ! rtmpsink location=rtmp://66.94.124.166:1935/show/stream
No such element or plugin ‘nvv4l2decoder’
No such element or plugin ‘nvv4l2h264enc’
Jaocb
What hardware are you using?
Hi. I am having the same issue. I am using Jetson Xavier NX with Jetpack 5.1.1 (rev 1) + DeepStream. Running the following command:
gst-launch-1.0 rtspsrc location='rtsp://192.168.1.10:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp' protocols=tcp latency=100 ! rtph265depay ! h265parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, width=640, height=480, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink drop=1
results in
no element "nvv4l2decoder"
I installed the gstreamer plugins:
sudo apt-get install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgstreamer-plugins-bad1.0-dev gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-alsa gstreamer1.0-gl gstreamer1.0-gtk3 gstreamer1.0-qt5 gstreamer1.0-pulseaudio
and
sudo apt install --reinstall nvidia-l4t-gstreamer
and it just does not work. Do you have any suggestions on how to install the missing “nvv4l2decoder” plugin?
