No valid metadata for frame
hi.
I launch decoder sample from MM API samples:
./video_decode H264 --disable-rendering --report-metadata ./no_metadata.h264
Output:
Why? This is bug?
This is my video file “no_metadata.h264”: https://drive.google.com/open?id=1Pm52RRMpzrVCzg1Mpomn5oWcJRhKbyNE
You may compare no_metadata.h264 to sample_outdoor_car_1080p_10fps.h264.
$ ./video_decode H264 --disable-rendering --report-metadata ../../data/Video/sample_outdoor_car_1080p_10fps.h264
Or inspect no_metadata.h264 through JM decoder
Hi.
Why do I need to compare something? I ask you to check my file and answer the question: why is the metadata not extracted in this example?
I see that there are no nal-units with type 5 (idr) in the keyframes in my file. Only aud,sps,pps,sei,single nal-units. Could this be the reason?
Then it must be said that the medadata cannot always be extracted, there are limitations. Or is it a bug.
In other words, if there is no idr nal’s, then the metadata will not be valid?
JM decoder cannot parse the h264 stream. It reports the error:
get_annex_b_NALU: no Start Code at the beginning of the NALU, return -1
Error while getting the NALU in file format Annex B, exit
We have reference h264 stream and would encourage users do initial debugging/comparison first. Probably I did not express in a soft manner. My apology.
hi.
i’m sorry for my video file. i converted him to valid h264 bitstream, JM decoder parse that stream ok.
Please, check again: https://drive.google.com/open?id=1LbYK7NRegoS00KCo1sfld4MeWRxXOU_N
JM decoder still shows
Warning: Decoding does not start with an IDR picture.
Your comment is correct. It has to start with IDR frame.
