Could you update your Jetpack version to 6.1 and DeepStream version to 7.1 and try that again? We have fixed many similar issue on the latest version, such like 277689 280216 279778.
Related topics
| Frame rate drops when saving jpg files in Deepstream 6.2 SDK | 39 | 2704 | April 6, 2023 | |
| Encode jpeg image with nvds_obj_enc_process Segmentation fault | 6 | 520 | June 13, 2023 | |
| Pipelines with jpegenc and multifilesink produce invalid jpeg files in DS 6.4 | 1 | 356 | January 29, 2024 | |
| Nvv4l2decoder ! nvvideoconvert ! jpegenc pipeline issue | 3 | 164 | July 23, 2024 | |
| Correct inference on frames, but saved frames have artifacts | 31 | 533 | August 5, 2025 | |
| An exception occurred while saving the jpeg file | 8 | 587 | January 25, 2024 | |
| Jpeg encodeFromFd makes corrupted frame | 6 | 784 | October 20, 2022 | |
| Nvds_obj_enc_process for whole frame leaves aritfacts over time | 24 | 1718 | August 9, 2022 | |
| Deepstream-image-meta example issue on jetson | 31 | 2398 | October 12, 2021 | |
| Pixelated Frames in Deepstream Pipeline | 20 | 482 | September 30, 2024 |
