I am using 64 GB SD card and followed the instructions given in Getting Started with Jetson Nano 2GB Developer Kit | NVIDIA Developer
but after inserting the SD card into board we are getting errors
as shown in the image
Board set up failed
The installer encountered unrecoverable error, A desktop session will now be run so that you may investigate the problem or try installing again
we tried to install again but the problem is repeating the same
Please provide some solution
